Reomving the gearing restrictor- scooters
matttttt
PostPosted: 15:51 - 10 Feb 2005    Post subject: Reomving the gearing restrictor- scooters Reply with quote
I want more top speed on my speedfight 2, I have read that removing the gearing restrictor in the variator body will improve the speed.. Will I be able to do this myself... I'm not to good with mechanics.. but how hard is it? Also what are the down sides to this operation?
matttttt
PostPosted: 16:38 - 10 Feb 2005    Post subject: Reply with quote
boost Razz
divuk83
PostPosted: 17:49 - 10 Feb 2005    Post subject: Reply with quote
No downside to it. Will gain a fair bit of speed and should be simple enough to remove. There is a guide thingy on this site that was stolen from another site!
https://www.sc-ooter.50megs.com/derestriction.htm
https://www.sc-ooter.50megs.com/4restrict.sized.jpg
Dave
matttttt
PostPosted: 00:59 - 11 Feb 2005    Post subject: Reply with quote
Cheers mate, is it the same assembly and parts on a speedfight 2?.. I'm also not too sure if it has the correct rollers in... it has a zx leo vinci pipe but I brought it 2nd hand so I'm not too sure what's been put into it in terms of rollers.. If I wanted to get a "gear up kit" after... would taking the plate from the variator hinder this possibility?.. How much would a motorbike shop charge to take the plate from the variator and check the rollers are the correct weight or make or whatever to gain maximum speed?
binge
Emo Kiddy
PostPosted: 01:08 - 11 Feb 2005    Post subject: Reply with quote
Ok. For the restrictor. its simple enough if you have the knowledge/correct tools.
Unless you have an impact wrench/Air gun or a flywheel puller, I wouldnt attempt it yourself as you have very little chance of getting the front hub off the variator.
A garage will charge around £35 an hour. The minimum they will charge is a 1 hr fee. It takes me about 10 minutes to do a roller change. So I presume a garage would take about that time, But In the book its down as a 1 hour job. So they will charge you around£35 + Parts + VAT.
So you are looking at £50 (If you need rollers fitting)
The ZX pipe usually comes with 4.5g rollers and 5.2g rollers
The 4.5g rollers make your revs pick up a bit quicker but the mid range is usually a bit flat. The 5.2g rollers will give you slightly slower rev pick up but you will have a much smoother mid range. (Well that was what I had)
<|Ben|>
The last post was made 21 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 43.59 Kb
