GPZ 500 oil level sight question
dn38416
PostPosted: 18:05 - 02 Dec 2015    Post subject: GPZ 500 oil level sight question Reply with quote
Right, apologies for the simplicity of this but i'm not twigging something, and i don't have a manual to tell me what's normal.
Just got a 2003 GPZ 500S, when i run it, the oil window empties out almost completely, then when i stop it and leave it on the centre stand the oil fills the entire window...above the max level*.
Obviously when i saw the latter i started trying to draw some out using a tube, maybe 100 - 200ml but made no difference in the level window. Now i'm not sure if i've taken too much out, the engine started smoking when i last started it up but that might just be some stray parrafinbeing flung off the chain onto the casing.
*Strangely this how to guide says it can be either between the lines, OR completely full...then what's the point?
https://www.ifixit.com/Guide/1994-2009+Kawasaki+Ninja+500+Oil+Change/6470
PostPosted: 18:36 - 02 Dec 2015    Post subject: Re: GPZ 500 oil level sight question Reply with quote
Then irrespective of what you've been told about the service history, dump the oil and filter refill (gradually) with fresh.
RhynoCZ
PostPosted: 19:03 - 02 Dec 2015    Post subject: Reply with quote
Are you sure you check the oil right? Is it really supposed to be checked on the center stand? Are you sure the motorcycle is straighten up properly? We, without the center stand, know that tilting the motorcycle 10mm left or right can mean empty or overfilled looking at the check glass. Wink
As Roger says, drain it, fill up with proper amount. IF you are sure you know how to check the oil level. We have met quite a few stupid people here. Thumbs Up
PostPosted: 19:38 - 02 Dec 2015    Post subject: Reply with quote
Emptying when the engine starts is good. That means your oil pumpis sucking the oil up and pumping it to the top of the engine. Thumbs Up
Oil should be between the lines at the top and bottom of the sight glass with the engine warm but not running and the bike straight and level.
I'll echo Roger. If you just bought it, service it. Oil, and filters at a minimum.
dn38416
PostPosted: 20:03 - 02 Dec 2015    Post subject: Reply with quote
Brilliant, tar very much guys! This is my first big bike.
pompousporcup...
PostPosted: 10:12 - 03 Dec 2015    Post subject: Reply with quote
fwiw (and i agree with the change it now with new filter) running it with the oil level "slightly" above the glass is unlikely to do much... its just difficult to tell how much over it is.
i run mine at the top of the glass. no issues here
The last post was made 10 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 49.09 Kb
