Akwardly Placed Nuts (cg125 seat)
Falco
PostPosted: 00:40 - 03 Dec 2015    Post subject: Akwardly Placed Nuts (cg125 seat) Reply with quote
This isn't a mechanical question as such; to remove the seat on the CG125 2 nuts need to be removed. These are placed under the seat behind the rear mud guards. I need to do this as the side stand snapped a couple of weeks ago and dumped the bike on its side. Since then there has been a rattling noise from the front which I am pretty sure is the bolt holding the petrol tank (the rattle diminishes if I hold the tank with my knees when riding and stops entirely if I sit quite far back and hold it where the tank goes under the front of the seat).
The problem I am having is that I can't get at the nuts to unscrew them (they are actually square nuts). From the back I can't get a ratchet close enough since the rear shock absorber is in the way, from the front with the battery cover off the angle is too awkward. I have a universal joint and a stubby ratchet but I am making no progress. Is there a trick to it? Is there a special sort of tool for accessing such awkwardly placed nuts?
It seems like removing the rear shock absorber would be overkill (plus I would not be comfortable doing that at this stage).
Kawasaki Jimbo
PostPosted: 00:52 - 03 Dec 2015    Post subject: Reply with quote
Finger ratchet perhaps (Google)? Or remove some panels for access.
PostPosted: 01:43 - 03 Dec 2015    Post subject: Reply with quote
Square nuts are usually captive welded nuts. If they are loose and rotating it usually means the bolt is rusted fast in the nut and whomever lest tried to un-do them broke the welds instead.
Falco
PostPosted: 01:42 - 09 Dec 2015    Post subject: Reply with quote
Thanks for the help guys.
As it turned out, with the arrival of the Haynes manual yesterday, advice from here and a liberal application of common sense, the problem was resolved. Turns out I was trying to undo the captive welded nuts that hold the tail fairing on Embarassed
One less mistake to make next time I suppose
The last post was made 10 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 44.61 Kb
