Nsr 125 fork springs
Burnzy1989
PostPosted: 20:45 - 01 Dec 2015    Post subject: Nsr 125 fork springs Reply with quote
Hi all does any one know if the fork springs from a nsr 125 jc22 will fit the jc20 fork as I'm going to need the spring rate the same as the rear on a jc22 on my jc20. Thanks all
alains
PostPosted: 11:00 - 03 Dec 2015    Post subject: Reply with quote
unfortunatly not , they have different length
are you sure that your spring is worn , even with the years of use i havnt seen that
if you look on the workshop manual you'll see the mesurements of it
service limit 320mm (12.5 inches)
Burnzy1989
PostPosted: 13:29 - 03 Dec 2015    Post subject: Reply with quote
No just want to stiffen it up the forks the rear is going to have a rear shock off a jc22 iv modified the top bush so it will fit in the frame. So I may need the front stiffening up slightly
alains
PostPosted: 15:30 - 03 Dec 2015    Post subject: Reply with quote
very simple , fill the forks with SAE20W (280 ml)
as i weighted 16 stones , i done that on my bike
i can tell you that the JC22 springs are 336 mm long
Burnzy1989
PostPosted: 18:07 - 03 Dec 2015    Post subject: Reply with quote
Ahh I will try that and would like to set the sag though for the hole bike so it works well to my weight
The last post was made 10 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 41.6 Kb
