| jagwaugh |
 jagwaugh L Plate Warrior
| WD Forte |
 WD Forte World Chat Champion
 Posted: 15:41 - 03 Dec 2015 Post subject: |
| jagwaugh |
 Posted: 15:46 - 03 Dec 2015 Post subject: |
Thanks, I have the schematic,via google. Unfortunately, the schematic doesn't list the pinout. |
 Posted: 16:00 - 03 Dec 2015 Post subject: |
What you have is correct according to the diagram I'm looking at.
Check your bulb wattages. Make sure the repeater light bulb is intact. Make sure the housing of the repeater bulb is insulated from the frame as it's sometimes live.
You should be getting power at the orange wire. Try hooking that directly into an earthed flasher bulb. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jagwaugh |
| jagwaugh |
 Posted: 12:40 - 04 Dec 2015 Post subject: |
It's possible but AC/DC systems are odd beasties at the best of times.
The AC frequency alters with revs as well as the voltage so the RMS doesn't necessarily reflect the overall power output.
The lighting will be tasking power out while this happens too.
There are so many variables, it's difficult to predict its behaviour. Looks like yours just has a single coil on the actual power supply part so I'd suggest if it's making power at all, the coil is intact.
The ignition is on a totally seperate circuit to the lighting/accessories. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jagwaugh |
 Posted: 17:24 - 04 Dec 2015 Post subject: |
Yeah, most of the AC/DC systems I've seen just use a straight diode. Not even a regulator, they just use the battery to damp down the voltage. I doubt yours will contain anything much more sophisticated. They generate a lot of heat in use, probably why a lot of them fail.
What's different with yours compared to most I've seen is that it seems to take all the coil output then somehow split it between the battery and the lights. Most small bike systems I've seen use a split magneto coil where they use the entire coil to charge the battery with the lights off and use a take-off halfway along the windings to split the output with the lights on.
An odd bike has a 12v AC regulator. The only two I've seen are on Lambrettas and late Enfield Bullets and they use one of the three phases for the AC componant.
I once had a russian bike that ran entirely on 6V AC. All good until you need a new horn or flasher relay...
Be aware than many of them are extremely fussy about the current loading on the AC side. If you fit bulbs with too high a wattage, they'll all be dim. Too low a wattage and they pop. A classic is a cascade bulb failure. One bulb goes and the rest pop one after the other. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jagwaugh |
The last post was made 10 years, 350 days ago. Instead of replying here, would creating a new thread be more useful? |
