Dr350 valve adjustment
Dedge1
PostPosted: 22:17 - 03 Dec 2015    Post subject: Dr350 valve adjustment Reply with quote
Hi I've just bought a dr350 I need to adjust the valves on the exhaust side how do i know when the bike is on the compression stroke and that I have the valves in the right place so that I can make the adjustment any help would be great😊😊😊😊. Thanks👍👍👍[/list]
Ariel Badger
PostPosted: 22:48 - 03 Dec 2015    Post subject: Reply with quote
Plug out, pencil down the hole and judge the top of the stroke. If both valves are shut then you are on TDC compression. there may be a mark on the timing gear but my way is old school and works.
yen_powell
PostPosted: 23:05 - 03 Dec 2015    Post subject: Reply with quote
Turn the engine till the mark lines up on the end of the crankshaft, wiggle the tappets, if they don't move make another complete turn of the engine and try again. if they both move a little you're in the right place.
If you do the pencil trick, don't let it get caught and snap off Embarassed
XT1200Z and a DR350 in bits
Ariel Badger
PostPosted: 23:43 - 03 Dec 2015    Post subject: Reply with quote
My mate did break the pencil, we just started the motor and reved it, a few sparks came out of the pipe but that was all.
Dedge1
PostPosted: 00:43 - 04 Dec 2015    Post subject: Reply with quote
Thanks for the info it makes more sense than other things I've been reading on google etc.... Some sites tell you how to do it but go on for so long you forget where to start. Lol... That's sound nice an simple so hopefully should go alright fingers crossed😊😊. Thank you for the info.👍👍👍👍
Fizzer Thou
PostPosted: 03:07 - 04 Dec 2015    Post subject: Reply with quote
Make sure that there is some free play on the manual decompressor cable as I have a friend who bout a DR350S and he played with valve clearances for ages before he realised that it was this cable that was holding the valve open unintentionally Shocked
Always have a 'Plan B'
The last post was made 10 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 48.25 Kb
