Fuse keeps blowing
Dedge1
PostPosted: 16:07 - 05 Dec 2015    Post subject: Fuse keeps blowing Reply with quote
I have a dr350 and when I switch the left side indicators on it keeps blowing my fuse not to clued up on electrics could someone help me out as to what I could check for and what might be causing it thanks
MCN
PostPosted: 16:54 - 05 Dec 2015    Post subject: Reply with quote
Bad Bulb. There is an in-built fuse in bulbs which should fail to protect from overheating fire etc..
There may be a short-circuit between the terminals of the bulb cuase by rust/corrosion.
Electrics on most vehicles uses a loop from the + post of the battery to the - post. This is a circuit.
The power normally goes from + to the switch then to the Bulb (consumer) through the bulb to '- (ground) which is normally a metal frame. It then passes through the metal frame to the - Post of the battery which is connected to the frame by a short cable.
You might need t get a hold of a multimeter. They're not too expensive and can save hours of heartache and provide a lifetime of fun. Smile
Open the lamp and remove the bulb. Clean the connections in the bulb holder.
Dedge1
PostPosted: 17:45 - 05 Dec 2015    Post subject: Reply with quote
Thank you for the reply I'll check and clean all the connections then and hope it goes well thanks for the advise😄😄😄👍👍👍
bugeye_bob
PostPosted: 17:58 - 05 Dec 2015    Post subject: Reply with quote
not sure what MCN put as I have idiots blocked,
might be worth removing the lamp and seeing if it still does it , if not then you are looking for a short/damage to the wiring for that indicator, so its worth working along the wires for anything obvious.
MCN
PostPosted: 18:24 - 05 Dec 2015    Post subject: Reply with quote
You can most probably ignore anything bugeye_nob wrote.
Not everyone on the forum plays/knows how to play with a full deck of cards.
The last post was made 10 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 43.57 Kb
