| ProXimaCore |
 ProXimaCore Dougal
 Posted: 16:16 - 10 Feb 2005 Post subject: Leaking fuel when start. Wheel wont go on either. |
I'm working on my bike today. I've spent an hour trying to get the back wheel on. It's not for happening. It wont fit by 1mm. Pain in the arse. Not to mention you need 4 arms to try and get the thing on while holding the bits in place and then knock the bolt through. But that's not my main concern just now...
To make things even worse, I just tried starting the bike. It's got old fuel in it so i figured it wouldn't go. It did start eventually after 10 mins. When it did start, all this fuel started pouring out the bottom of the bike from somewhere. I mean loads of it! Quickly turned the bike off and it slowly came to a stop. There's still some fuel in the tank. No idea what happened. It's just been sitting there all winter, I haven't touched any of that part. Any ideas what caused that?
 ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| cc123 |
 cc123 Geez a joab?
 Posted: 16:25 - 10 Feb 2005 Post subject: |
Any chance of a cracked fuel line or something with the cold?
I have no idea wot I'm talking about!! ^^^^
Have you tried to drain the old fuel from the carbs? Maybe the screw is slack or undone causing the fuel to pour out?? ____________________ Old bikes >>> https://www.bikepics.com/members/cc123/ |
| Scotsman37 |
 Scotsman37 World Chat Champion
| Git |
 Git Brolly Dolly
| AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
| catgate |
 catgate Two Stroke Sniffer
| Guest |
 Guest Brolly Dolly
| AcIdBuRnZ |
| cc123 |
 cc123 Geez a joab?
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 10:59 - 11 Feb 2005 Post subject: |
I just noticed something. The fuel tap was on prime for over 3 months. Would this have caused the problem?
Wheel is still being a bugger. I need someone to help me. But they're all complaining it's too cold to go outside.  ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| instigator |
 instigator Super Spammer
| Git |
 Git Brolly Dolly
| ProXimaCore |
 ProXimaCore Dougal
| cc123 |
 cc123 Geez a joab?
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 13:31 - 11 Feb 2005 Post subject: |
Well I got the wheel on after great difficulty.
Tried bumping the bike down the hill. Engine didn't even make a sound. Just locked the wheel. What should I do from here? ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| cc123 |
 cc123 Geez a joab?
 Posted: 13:34 - 11 Feb 2005 Post subject: |
Can you not use jump leads rather than bump it? Might be more successful getting it started? How long has it been sitting?
My mate started up his Bandit only 2 weeks ago after sitting for 2 months, took at least 10 mins to get fired up and running. Started using jump-leads tho....?? ____________________ Old bikes >>> https://www.bikepics.com/members/cc123/ |
| ProXimaCore |
 ProXimaCore Dougal
| cc123 |
 cc123 Geez a joab?
 Posted: 13:44 - 11 Feb 2005 Post subject: |
Have you not found out where the leak came from then?
I dunno. I'm no mechanic...
Simple things but don't take offence.....
Check the fuel tap is back to on?
Any chance maybe you've bumped the kill-switch to off and not noticed? ____________________ Old bikes >>> https://www.bikepics.com/members/cc123/ |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 14:39 - 11 Feb 2005 Post subject: |
Crap, I'm just making this worse. Took the tank off. There's 4 hoses on the underside. 3 of them on the tap, and one just over a bit on it's own. When I took the tank off I accidentally detached the hose that's on it's own at the bike end instead of the tank end. I don't know where it came off the bike though. So now I'm stuck. Does anyone know what this sounds like it came from?  ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
 Posted: 14:41 - 11 Feb 2005 Post subject: |
Normally prime allows the fuel to flow when the engine is stopped on bikes with vacuum fuel taps, while on and res will not allow fuel to flow unless the engine is running.
I would have said that you have a needle valve problem, or possible a broken / displaced fuel line. However if it was left on prime then both of these would dump the fuel out whether the engine was running or not (depending on where the breather and overflow hoses go).
As such I would guess that maybe the bike has dumped a very large amount of fuel through the carbs and into the crankcases. When you have started the engine up it has pumped a load out of the crankcase breather hose. To check for this, check the oil level. If it is high or stinks of petrol then change it immediatly (and do not try running the engine until you have done so), as petrol is a very poor lubricant.
I had a similar problem on the Bandit just from leaving it on prime overnight. It dumped about 3/4 of a tank of fuel through the carbs and into the engine and airbox due to a sticking float.
While you are playing check the carbs over carefully and also the fuel hoses.
| ProXimaCore |
 ProXimaCore Dougal
| cc123 |
 cc123 Geez a joab?
 Posted: 15:29 - 11 Feb 2005 Post subject: |
So you can fix it?
Don't want you missing out, looks like valver ain't coming, can't get a clutch lever for his bike ....  ____________________ Old bikes >>> https://www.bikepics.com/members/cc123/ |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 16:03 - 11 Feb 2005 Post subject: |
The last post was made 21 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
