How to fix rattly mirror
EasyGoingPat
PostPosted: 21:22 - 06 Dec 2015    Post subject: How to fix rattly mirror Reply with quote
Hi,
The glass in my left-hand mirror rattles annoyingly, blurring my view at low revs. Can anyone suggest how I might fix this?
I thought of trying to get some bathroom sealant and maybe trying to lever the lower edge of the mirror housing away from the glass just enough to get a fine-tipped applicator in there. If I could squeeze even a small amount behind the mirror, I am sure it would stop the rattle.
Does anyone have any better ideas?
Kind wishes ~ Patrick
Question
Thank you to anyone taking the time to read my posts.
Itchy
PostPosted: 21:32 - 06 Dec 2015    Post subject: Reply with quote
Are they adjustable as in the glass and not the body/mounting? If not and your RS1100 drill a small hole in the bottom and pump it full of bathroom silicone.
Adds weight (less vibes to distort).
Teflon-Mike
tl;dr
PostPosted: 21:36 - 06 Dec 2015    Post subject: Reply with quote
What bike? What sot of mirror?
Trying to combat the fuzz-effect all mirrors seem to suffer, from new or eventually, depending on how good they are to start with, I have tried all manner of 'mods' over the years, from using wheel weights stuck on the back, silicon sealant, to filling the cases with epoxy and air-gun pellets...
Feel free to experiment, to your hearts content; BUT the likely conclusion is simply to buy a pair of new, OEM quality mirrors.
Snodvan
PostPosted: 21:39 - 06 Dec 2015    Post subject: Reply with quote
Had this problem. If the mirror cases are black plastic then do as Itchy says and drill a hole in the plastic face opposite the mirror low down and squeeze silicone into it. You can buy BLACK silicone!! Let the excess set and trim it off - hardly be seen'
Snod
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
PostPosted: 21:54 - 06 Dec 2015    Post subject: Reply with quote
Yep drill a hole in the back at the bottom middle and squirt in some cheapo silicone. Use a drinking straw to get it right at the top then squirt a good amount just into the hole. Rattles will stop.
EasyGoingPat
PostPosted: 23:15 - 06 Dec 2015    Post subject: Reply with quote
Thank you for all those comments. I will give the idea of drilling a small hole and using black silicone sealant a go. I'll report back when I've done it.
- Patrick
The last post was made 10 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 55.06 Kb
