| krikster |
 krikster L Plate Warrior
 Posted: 15:45 - 05 Dec 2015 Post subject: Bike will / won't start |
Ok here it goes.....I have a bike that I have gone through with a fine tooth comb trying to figure out the problem. The bike has a new battery, new plugs, new fuel, new stater, and new switch. However if I use the switch to try and crank it, it will try to crank, but no start. Yet if I roll it off it cranks in the first 5 feet of a small roll. So that tells me the engine is easy to start, but for some reason will not fire up when using the switch.
P.S. Tried checking to see if the starter was weak by using jumpers with a car and still did the same as just the battery itself!
What could possibly be the issue in this freaky situation?  |
| NJD |
 NJD World Chat Champion
 Posted: 15:53 - 05 Dec 2015 Post subject: |
Telling us what bike you have may be a good place to start.  |
| krikster |
| Robby |
 Robby Dirty Old Man
 Posted: 18:29 - 05 Dec 2015 Post subject: |
are you saying that it will crank over on the button but not fire up but if you push it and bump-start on the clutch it will fire up easily? ____________________ a.k.a 'Geri'
| krikster |
| P.addy |
 P.addy Red Rocket
| Polarbear |
 Polarbear Super Spammer
| krikster |
| Luckyfish13 |
 Luckyfish13 Renault 5 Driver
| krikster |
| P.addy |
 P.addy Red Rocket
 Posted: 16:19 - 06 Dec 2015 Post subject: |
Yep we worked all day on that bike and couldn't find a solution. The only cure to hand was to wire a second battery between the starter solenoid and the starter and it was on the button every time after that. I think it was a fault in the loom personally but without stripping the whole loom apart we'd never know. ____________________ a.k.a 'Geri'
| Luckyfish13 |
| Robby |
 Robby Dirty Old Man
 Posted: 20:19 - 06 Dec 2015 Post subject: |
It takes very little electricity to make a spark, it takes a lot to crank an engine.
However, if the battery is weak - or the starter motor resistance is very high - then the starter motor seems to take all of the power, not leaving enough to make a decent spark.
So, questions:
1. Start motor cranking. You say it cranks the same whether it is using the bike battery or using the bike battery and an additional car battery. Does it crank good and fast, or is it a bit sluggish?
2. New battery. Did you charge the new battery, or just fit it? Have you charged it since doing all of this experimenting? Always diagnose problems like this on a good condition battery that has been on a charger overnight.
If the battery is charged then the next place to look would be the thick wires between battery and starter motor. The red wire should go from battery to solenoid and then solenoid to starter motor. The black wire will only go part of the way, using the frame/engine as a general ground.
The bike is 31 years old so corrosion is going to be a problem, particularly where dissimilar metals meet. Check where the thick earth (black) lead meets the frame or engine for corrosion. If you find any, clean it up. Also see if any of the thick leads are frayed near their ends. For a real shortcut, run an additional thick earth lead from the starter motor back to the relay.
If none of that works, I would be stripping down the starter motor.
Also, you keep saying you replaced the stater - I assume you are referring to the stator plate and not the starter motor. It's a misspelling which could lead to very different advice being provided. |
| krikster |
| chris-red |
| 331X2 |
 331X2 Crazy Courier
The last post was made 10 years, 285 days ago. Instead of replying here, would creating a new thread be more useful? |
