Think I broke the engine, what now?
talkToTheHat
PostPosted: 20:06 - 07 Dec 2015    Post subject: Think I broke the engine, what now? Reply with quote
So riding back from the dentist, traffic is busy but moving, 2 lanes opens into three, power, change into 3rd power then CLUNK and engine goes quiet, back end is loose so I pull the clutch and coast, get into left hand lane, metal barriers all the way along side of the road. I find neutral and thumb the starter. CLONK. I hop of, and pussh bike to the first place I can pull in. No visible damage. Have oil. Smells normal. Phone RAC. Somehow they are convinced I'm describing a dead battery. Orange van in minutes. By which time I've already phoned local independent garage. RAC man sighs at description of fault, apologises profusely for his phone team and summons a recovery truck. Bike is now sat in garage awaiting a diagnosis, but mechanic says it's probably terminal.
How do I shift a non-runner ten miles from my home if it is fucked? What kind of money can I expect to get for her. 92 XV535, cosmetically tidy.
Replacement wise, I need to do sooner rather than later. I don't walk very well, to the point where how the fuck do I do my food shopping is suddenly a major issue.
I want something with a more upright riding position than a sportsbike that's going to be reasonably cheap to run. I would like to be able to fit hard luggage. I have two Givi E45 and two E21 boxes I'd like to be able to use, but if it turns into keeping an E45 as a topbox and finding the more modern givi side box system I won;t be too upset.
I am considering bandits and fzs600s. I think the fazer would be more fun. I think the bandits might be more sensible, especially if I can find a 650 ABS. Thoughts?
Bandit. does. everything.
PostPosted: 20:09 - 07 Dec 2015    Post subject: Reply with quote
Sounds like a thrown rod or a dropped valve. Maybe not terminal but not far off. 535's rot so fast there should be an engine out there somewhere.
talkToTheHat
PostPosted: 20:21 - 07 Dec 2015    Post subject: Reply with quote
£350 buys an engine with more miles on than mine. How many hours of mechanic time to swap? I'm limited to pre 1994 engines unless I source new engine management and rejet the carbs. Quickly spirals.
PostPosted: 20:23 - 07 Dec 2015    Post subject: Reply with quote
Why did yours shit itsself? Any idea yet. Listen to Pete. he knows his shit. Thumbs Up
stevo as b4
PostPosted: 20:27 - 07 Dec 2015    Post subject: Reply with quote
Id get the bike home, and investigate more. Check compression, look at the plugs etc, and then at your leisure strip it down as required to see what damage has been done and what you need to replace.
In the interim any bike would do wouldn't it? Even a cheap 250cc scooter or a commuter bike maybe?
I wouldn't want to plan on replacing my main bike, until I knew it was beyond hope or way too expensive to fix?
PostPosted: 20:46 - 07 Dec 2015    Post subject: Reply with quote
Pull the plugs and shine a torch down the hole. If you see no obvious debris turn the engine back and forth by hand on the crankshaft end nut and check if the pistons are moving in time with the crank. FI they are the camchain has probably snapped.
talkToTheHat
PostPosted: 21:09 - 07 Dec 2015    Post subject: Reply with quote
My bike is at the local independent garage. I trust them. It arrived at close of business today, inspection cameras going in first thing tomorrow. Mechanic's gut feeling is it's a dropped valve. That this happened under power at about 5000rpm means whatever crapped out did so with some force. If we don't find all the bits we broke it's wasting money.
I don't have the facilities nor the physical fitness to do a major overhaul. I don't talk about how ill I am much on here, or anywhere really. The bike hides a lot from the rest of the world. With it I do a reasonable impression of a functional human. A big guy in bike leathers leaning on a shopping trolley hobbling around the supermarket is invited to exchange crash stories. A young person with a walking stick is treated like the scum of the earth.
Particularly looking at a blandit I'm thinking commuter bike. I do about 500 miles a month, mixture of large town, back roads and the occaisonaly bit of NSL dual carriageway or motorway. Occaisonal 2 up. Occasional long trip. Never without luggage. Typically lots of ten mile trips.
bugeye_bob
PostPosted: 21:38 - 07 Dec 2015    Post subject: Re: Think I broke the engine, what now? Reply with quote
Internet shopping is available now days, infact I believe all the major supermarkets deliver, so no real panic food wise.
duhawkz
PostPosted: 21:42 - 07 Dec 2015    Post subject: Reply with quote
Ha ha beat me to it.
I was just going to point out that internet grocery shopping is actually a thing.
So there's no need for OP to starve (or get a taxi to the shops)
talkToTheHat
PostPosted: 22:23 - 07 Dec 2015    Post subject: Reply with quote
MrGs1 wrote:
the headlights on the box eyes are shit
Good to know. Ride at night lots.
Wingracks with the FZS fitting kit are like gold dust so forget panniers unless you can modify an FZ6 one to fit.
How easy is that to do? How close a fit are the FZS1000 racks?
PostPosted: 23:11 - 07 Dec 2015    Post subject: Reply with quote
That's an understatement. Our Fazer 600 hack is actually frightening to ride on an unlit country road.
Wifie had a watercooled 650 Bandit with ABS. I actually quite enjoyed riding it Embarassed but she found it very top heavy. Finish wasn't good, invest in ACF50 or FS365. ABS is front wheel only and pretty agricultural but works. I found it a very comfy bike.
Triumph Trophy Launch Edition
PostPosted: 23:40 - 07 Dec 2015    Post subject: Reply with quote
Polarbear wrote:
Wifie [...] very top heavy.
Me too. If you have wobbly legs, avoid any sort of camber or bad footing.
Conversely the Nazi Tractor F800 range with the under-seat tanks are notably stable. 65mpg+, luggage options, flexible engine, 2-up capability.
They can be had for Bandit 650 money.
talkToTheHat
PostPosted: 14:27 - 08 Dec 2015    Post subject: Reply with quote
My mechanic says a bearing on the crankshaft has disintegrated. Possible damage to crankshaft, a con rod and possibly crankcase. Metal everywhere so likely to have contaminated other bearings and in need of a very meticulous rebuild or taking a leap of faith on a 25 year old engine.
I think this one's a goner.
PostPosted: 14:53 - 08 Dec 2015    Post subject: Reply with quote
Gumtree, "was running great until it wasn't, prolly an easy fix tbh". Whistle
blueglue
PostPosted: 15:23 - 08 Dec 2015    Post subject: Reply with quote
must be worth about £500 as a non runner?
Matt B
PostPosted: 17:41 - 08 Dec 2015    Post subject: Reply with quote
If you are looking at Bandits then the oil/air cooled 1200 is the only one worth bothering with. It is a seriously under-stressed GSXR1100 derived engine that will take a lot of abuse. The big torque of the 1200 makes it easy to ride, smooth roll on power in any gear. Easy to work on and parts are plentiful. Downsides are that they often look like the owner ram raided Demon Tweeks, can look scabby and are not the best on fuel. Great bike though if you can find an honest un-messed with example, everybody should own one.
stevo as b4
PostPosted: 19:23 - 08 Dec 2015    Post subject: Reply with quote
Why is the 1200cc the only one worth bothering with though?
The 600cc is still under stressed too, and is 6bhp down on the GSXF600 engine, and as per the closely related GSXR750 engine, it can be taken out to 884cc with a big bore kit.
I wouldn't say the 600 or 1200 Bandit are better than each other, Id buy one on condition and even colour before if it was a 600cc or a 1200cc version.
I think an 884cc kitted bandit, with GSXR cams and engine bits etc, along with say some SRAD 600 brakes, forks and a decent rear shock would make for a very good sleeper Bandit too.
Even though I'm not in the slightest bit into the Sleeper look/spec.
redeem ouzzer
PostPosted: 21:19 - 08 Dec 2015    Post subject: Reply with quote
The 600 Bandit isn't fast enough for modern roads.
1198
PostPosted: 23:11 - 08 Dec 2015    Post subject: Reply with quote
Mr Hat, where are you / the bike based?
talkToTheHat
PostPosted: 23:37 - 08 Dec 2015    Post subject: Reply with quote
Which are invariably more shit than when the 1200 was born because nobody fixes the potholes. I live in the sticks, the 535 was adequate on 33bhp, and did pillion motorway duty derestricted. Most of the local motorways seem to be stuck at 50 because roadworks or due to smartness.
Conversely I consider the R1 I borrowed completely irrelevant for the road and the VFR to be sublimely fast way to hurt my wrists and lose my licence.
I don't need a 1200. I'm calling in favours to scrape together the money for a bike and amongst the criteria I need to fulfil is "something not likely to be an endless run of expensive problems", "something that won't have [me] complaining it's to slow on motorways" and "not excessively fast"
Yes, some of this criteria comes from my mother, who both worries about me and gets confused when I say I'm not coming to vist because the weather is bad (and then promptly stacks her polo becasue ice) or thinks the reason I avoid motorways unless I am really pressed for time is that the bike isn't fast enough (and then complains that she can't keep up with me when following me to a restaurant). True when I had a 125 motorways were not fun on grounds of insufficient speed, but I had a 125 off of L-plates for less than 24 hour hours before chopping it in for something bigger.
Conclusion, an 'a2' bike is enough, so a soft 600 will keep me in backroad giggles for a while and do far more than I need. Yes, I'd like an XJ1200 or similar big lump of muscle bike but it's beyond what I need.
stevo as b4
PostPosted: 23:48 - 08 Dec 2015    Post subject: Reply with quote
Although there's quite a big weight difference between them, the cunt inside me says that the GSXR750 slabbie is only around 20-25bhp more at best.
Who dares to call the iconic father of the modern superbike's too slow for modern roads? Wink
Ariel Badger
PostPosted: 00:00 - 09 Dec 2015    Post subject: Reply with quote
Do you have a full or an A2 licence? I would be looking at an MT03 on an A2. A hell of a lot of fun and little to go wrong.
talkToTheHat
PostPosted: 00:06 - 09 Dec 2015    Post subject: Reply with quote
The 535 is sat in Doncaster Motorcycles, I'm about a 15 minute drive to the west of there. Bike waiting for me to either pay them to dump it on my lawn or me to find enterprising chap that will pick it up from there.
I'll take offers from enterprising chaps on here if they want it. It has a fehing lightbar supporting cheap LEDs, givi monokey side racks that i believe were adapted from another vehicle in servaceable condition. Year old Motad exhaust. Bodywork, chassis and wheels are in good condition. I've got a boxful of original indicators and various bits and bobs that I can throw in. Screen and mirrors were removed to get the muffs off to get bike secured onto truck, I broke one of the mirrors pictured.
talkToTheHat
PostPosted: 00:11 - 09 Dec 2015    Post subject: Reply with quote
Full licence. last of the 33bhp passes. Referring to A2 as enough becasue unrestricted 535 makes a claimed 46 horses and is my entire basis for suggestions that A2 levels of power is adequate.
The last post was made 10 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 135.32 Kb
