KMX 125 Over-revving when applying clutch
dannywwww
PostPosted: 14:48 - 10 Dec 2015    Post subject: KMX 125 Over-revving when applying clutch Reply with quote
Hi,
I have a 1991 KMX. It's just started happening all of a sudden, when i apply the clutch it seems the RPM seems to be increasing quite dramatically.
I have recently done a top-end rebuild, seemed to be running smooth until now.
Is it possible that the clutch is slipping and the cable needs adjusting?
thanks
PostPosted: 14:57 - 10 Dec 2015    Post subject: Reply with quote
I'm not entirely clear what you mean by "apply the clutch". Do you mean when you pull the lever in or as you let it out?
Does it idle steadily when in neutral?
Are your engine mounting bolts tightened up properly? No movement of the engine within the frame?
dannywwww
PostPosted: 17:01 - 10 Dec 2015    Post subject: Reply with quote
Sorry for not being clear!
Yes, when i pull the clutch in the RPM increases dramatically. The engine is solid in the frame. Seems to run pefect in idle.
Taught2BCauti...
PostPosted: 17:15 - 10 Dec 2015    Post subject: Reply with quote
Sounds like you might have an issue with cable routing.
Try to follow the clutch outer cable from the lever to the clutch, and see if it fouls the throttle cable at any point.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 17:46 - 10 Dec 2015    Post subject: Reply with quote
Do the revs increase when you pull the clutch in in neutral without touching the throttle?
How about if you change from neutral into first then back into neutral again without touching the throttle?
Or is this something that only happens when you're riding and changing gear?
Ariel Badger
PostPosted: 18:50 - 10 Dec 2015    Post subject: Reply with quote
I imagine that your clutch cable has come into contact with the throttle cable and is interfering with its action.
Carvel
PostPosted: 12:34 - 11 Dec 2015    Post subject: Reply with quote
^ That.
Have you cable tied them together or something?
PostPosted: 19:05 - 11 Dec 2015    Post subject: Reply with quote
I was more wondering if there's a sticky throttle valve/cable.
So when you pull the clutch in to change gear, the revs will shoot up because the throttle hasn't fully closed.
Had this happen on the enfield when I was supplied with a dodgy throttle cable.
Hence my question about wether it does it in neutral.
The last post was made 10 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.93 - MySQL Queries: 13 - Page Size: 56.96 Kb
