| Nomad Z |
 Nomad Z Borekit Bruiser
| NJD |
 NJD World Chat Champion
| MCN |
 MCN Super Spammer
| bugeye_bob |
| Ste |
 Ste Not Work Safe
| smegballs |
 smegballs World Chat Champion
| Nomad Z |
| Copyhat |
 Copyhat Two Stroke Sniffer
 Posted: 21:06 - 12 Dec 2015 Post subject: |
| Nomad Z wrote: | I'll stay away from the Halfords bulbs, then.
| smegballs wrote: | What voltages are you getting up at the headlight bulb connector? |
Haven't measured the voltage yet. The bike has heated grips, but the light was poor before they were fitted, and I wouldn't say it's got any worse when the grips are running.
| Quote: | Higher wattage bulbs just make the problem worse as higher currents lead to more resistance and more voltage drop. |
Why would higher current lead to higher resistance?
Corrosion is always a possibility - will check that. |
Electrical resistance in cables follows Ohm's law which means that it functions as a resistor (with a fixed value) in series with your headlight bulb. You can measure the correct voltage if the bulb isn't plugged in, but the larger current drawn by the bulb compared to the multimeter drags the voltage down because the equivalent series resistance of the wiring isn't dimensioned for the current. The voltage drop becomes heat in the wiring, and it will melt the isolation and start fires if the current drawn far exceeds the cable's capabilities, which is why it is a good idea to use the correct fuses in an installation.
Imagine a long waterpipe where you want 12 bar of pressure on the far end of it. You can easily measure the same pressure at both ends of the pipe if we imagine a manometer in each end. If we open the tap in the far end, the water pressure will drop because it has to overcome the resistance of the pipe, while we can still measure the same 12 bar in the opposite end.
I hope it was clarifying for you. I am studying marine engineering with electrical engineering as a primary subject. ____________________ Past: '91 Honda NTV650, '93 Kawasaki GPZ 500S
Current: '91 Honda VFR750F, '83 Suzuki GSX400F |
| stonesie |
 stonesie World Chat Champion
| pinkyfloyd |
 pinkyfloyd Super Spammer
 Posted: 21:40 - 12 Dec 2015 Post subject: |
I fitted this
https://www.halfords.com/motoring/motorcycling/motorcycle-parts/halfords-bike-it-motorcycle-bulb-hmb472sbb-h4-12v-60-55w
Made a big difference to the OEM ones and it has been in the bike for over a year now. Not as bright as some I have seen but brighter than standard and no issues. ____________________ illuminateTHEmind wrote: I am just more evolved than most of you guys... this allows me to pick of things quickly which would have normally taken the common man years to master
Teflon-Mike:I think I agree with just about all Pinky has said. |
| talkToTheHat |
| smegballs |
| smegballs |
| WD Forte |
 WD Forte World Chat Champion
| Nomad Z |
| Nomad Z |
| smegballs |
| smegballs |
| kawakid |
 kawakid World Chat Champion
| pdg |
 pdg World Chat Champion
 Posted: 03:07 - 15 Dec 2015 Post subject: |
I've never had an issue with any bulb from halfords, they usually last about 3-10 years or so.
Plus, if you know someone with a special type of halfords card, the bulbs are about thruppence ha'penny each  ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
| Pigeon |
 Pigeon World Chat Champion
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| Nomad Z |
| Wafer_Thin_Ham |
| Nomad Z |
The last post was made 10 years, 319 days ago. Instead of replying here, would creating a new thread be more useful? |
