| john24ssj |
 john24ssj Trackday Trickster
| Nobby the Bastard |
 Posted: 22:29 - 05 Dec 2015 Post subject: Re: Possible vacuum leak Kawasaki ER-5 |
| john24ssj wrote: |
I saw some saying to spay carb cleaner on the carb holder rubber (boots) but I don't have I only got brake cleaner would that work? I also got propane torch could that be used as well?
Thanks guys  |
Any solvent that evaporates readily at room temperature will do, but you can buy a can of switch cleaner for £5. ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050 |
| stickybackbob |
 stickybackbob Trackday Trickster
| Suntan Sid |
 Posted: 23:24 - 05 Dec 2015 Post subject: Re: Possible vacuum leak Kawasaki ER-5 |
| john24ssj wrote: | Rebuilt the carbs, replaced float needle, air filter, oil filter and oil. |
Have you checked the carb diaphagm for leaks?
A friend of mine had the same problems, there was a tiny, tiny, split in one diaphragm, it was barely noticable, even with a magnifying glass, but it was still enough to cause massive problems! ____________________ "Everybody needs money, that's why they call it money!"  |
| john24ssj |
 Posted: 09:33 - 06 Dec 2015 Post subject: Re: Possible vacuum leak Kawasaki ER-5 |
| Suntan Sid wrote: | | john24ssj wrote: | Rebuilt the carbs, replaced float needle, air filter, oil filter and oil. |
A friend of mine had the same problems, there was a tiny, tiny, split in one diaphragm, it was barely noticable, even with a magnifying glass, but it was still enough to cause massive problems! |
No I didn't inspect the diaphragms, which I will take the carbs apart if I can't find a vacuum leak ____________________ Bikes: Honda CBR600Fi, Kawasaki ER5 |
| john24ssj |
 Posted: 16:38 - 06 Dec 2015 Post subject: |
Leak testing didn't do anything but I found two tiny tears in the right carburettor diaphragm.
https://i.imgur.com/m8yO7zT.jpg
How big of an impact would a tear in diaphragm make? ____________________ Bikes: Honda CBR600Fi, Kawasaki ER5 |
| 331X2 |
 331X2 Crazy Courier
| john24ssj |
| Suntan Sid |
| john24ssj |
| Suntan Sid |
 Posted: 00:11 - 07 Dec 2015 Post subject: |
I don't know if these carbs have their own, unique, peculiarities but my mate rebuilt his numerous times, he could never get them right though, (he's no fool and quite used to doing this sort of thing).
In the end he gave up and sent them off to someone for a rebuild, on an exchange basis.
The symptoms on his bike were:-
Very difficult starting.
Impossible to set the idling speed.
Sump filling with petrol, via the breather into the air box.
He had every part of the fuel sytem apart, tap, pipes, carbs, filter, etc.
Once he got the carbs back from the rebuild all the problems disappeared! ____________________ "Everybody needs money, that's why they call it money!"  |
| john24ssj |
 Posted: 07:57 - 07 Dec 2015 Post subject: |
| Suntan Sid wrote: | I don't know if these carbs have their own, unique, peculiarities but my mate rebuilt his numerous times, he could never get them right though, (he's no fool and quite used to doing this sort of thing).
Once he got the carbs back from the rebuild all the problems disappeared! |
Oh yeah has same issues, I fixed the sump filling issue. One of the float needles was not stopping petrol and filling the air box. I have modified the air box with a snorkel so if that ever happens petrol does not get in to the engine and I have replaced the float needles
Just need to wait for the diaphragm and hopefully the bike will be up and running by Wednesday. ____________________ Bikes: Honda CBR600Fi, Kawasaki ER5 |
| john24ssj |
 Posted: 15:45 - 12 Dec 2015 Post subject: |
Close to giving up on the bike now.
Got the new diaphragm installed it and checked the carbs all is good Put everything back and started the bike with choke on and was revving at around 2.5K, after a second turned the choke off and bike stalled so I adjusted the idle and started the bike again with choke the revs shot to 5k and with choke off runs at about 1.2K.
I balanced the carbs but something just isn't right when you rev the engine and let go on the throttle the engine is very slow to go back to 1.2K stays at 2.1K for few seconds which makes gear changing odd as the engine feels like it wants to rev.
Also with choke on it revs at above 5K
Very close to just selling the bike now spending way too much time fixing it compared to riding it. ____________________ Bikes: Honda CBR600Fi, Kawasaki ER5 |
| Suntan Sid |
 Posted: 17:14 - 12 Dec 2015 Post subject: |
Revs slow to drop to idle, normally means your mixture is weak, which could mean an air leak or the air screw is not set correctly! ____________________ "Everybody needs money, that's why they call it money!"  |
| john24ssj |
 Posted: 17:38 - 12 Dec 2015 Post subject: |
Thanks for the reply I will take a look into it.
I had few issues with the return cable as the throttle works with 2 cables sort of push/pull system. I might check that out as well ____________________ Bikes: Honda CBR600Fi, Kawasaki ER5 |
| john24ssj |
 Posted: 14:03 - 13 Dec 2015 Post subject: |
Ok I did remove the return cable and it's better now the throttle comes back right away but revs still climb down slowly here is a video of the bike running and revving.
Sorry about the bad sound https://www.youtube.com/watch?v=9bAWUCzMi6A ____________________ Bikes: Honda CBR600Fi, Kawasaki ER5 |
| john24ssj |
| Suntan Sid |
 Posted: 12:31 - 14 Dec 2015 Post subject: Re: Possible vacuum leak Kawasaki ER-5 |
| john24ssj wrote: |
- Fuel tap + carburettor float needle failed flooded air box
- Rebuilt the carbs, replaced float needle, air filter, oil filter and oil..........................................
What, if anything, did you do about the Fuel tap?
A bit of googling reveals that the seals within the tap can go on this model. Have you had the tap apart, did you replaced the seals?
There must be a solution to this problem, the symptoms you describe seem quite common on this model.
Are you absolutely certain the carbs are clean?
When my mate had this problem, there was, what appeared to be, a blob of wax on the end of the needle.
Have you rebuilt the carbs with new jets, gaskets etc?
Have you set the float heights correctly?
Is the pilot air screw set at the factory setting?
Have you blown through all the jets etc with an airline when cleaning/rebuilding the carbs?
From memory, it was very easy to connect up the wrong pipes on the underneath of the petrol tank!
While googling this problem there are suggestions that the return springs, in the carbs, may not be doing their job. Seems unlikely to me but, is there any chance you've, inadvertantly, swapped the springs around when you've had the carbs apart? ____________________ "Everybody needs money, that's why they call it money!"  |
| john24ssj |
 Posted: 12:51 - 14 Dec 2015 Post subject: |
Thank for the reply.
Yeah I replaced the fuel tap gasket and the o-ring so the tap seems to good now
Before the leak everything was fine so clearly when I took the carbs apart I did mess something up. I did not adjust anything the first time, all I need is removed the diaphragms and replaced the float needles. And that's most likely when I cut the diaphragms and possibly done something else to the carbs.
I will do another full strip down of the carbs this week and try to inspect things if I see nothing I will just give up.
[edit] I had some suggestions to have a look at choke slides:
https://i.imgur.com/FUrgtof.png ____________________ Bikes: Honda CBR600Fi, Kawasaki ER5 |
| Suntan Sid |
| john24ssj |
 Posted: 14:52 - 14 Dec 2015 Post subject: |
Yeah I did have that issue and I needed to adjust the left float which I did and their both even with bowl edge as per manual.
Another thing I might do is let it run idle for a bit and remove the spark plugs see if things are running lean or rich.
I wouldn't give up if I had time but it's taking way too much to do all this and it gets dark too quick
I have a day off on Wednesday I will once again take of the carbs and see what's what ____________________ Bikes: Honda CBR600Fi, Kawasaki ER5 |
| john24ssj |
 Posted: 19:18 - 14 Dec 2015 Post subject: |
Oh bollocks I just realised what I did. When I was cleaning the carbs I had them submerged under water and I am now wondering if water has blocked something off somewhere  ____________________ Bikes: Honda CBR600Fi, Kawasaki ER5 |
| john24ssj |
| john24ssj |
| Suntan Sid |
The last post was made 10 years, 303 days ago. Instead of replying here, would creating a new thread be more useful? |
