New rider need help
Doge
PostPosted: 17:05 - 12 Dec 2015    Post subject: New rider need help Reply with quote
Hi, i recently passed my CBT and bought a motorbike. Couple days ago i noticed some loose tubes, and one was completely burned. How could i fix this? I am new to motorkibes, so any help would be greatly appreciated.
It's Derbi Grp 125 Racing 2008
https://i.imgur.com/q2IiTKs.jpg
https://i.imgur.com/87tXIlk.jpg
https://i.imgur.com/WoSjsSn.jpg
https://i.imgur.com/bLgaoLn.jpg
https://i.imgur.com/O6d47uc.jpg
Thanks Smile
Andy_Pagin
PostPosted: 17:38 - 12 Dec 2015    Post subject: Reply with quote
The clear tubes look like overflow/ventilation tubes, so just replace them with something similar. Not so sure about the rubber tube though. How's the bike running?
Doge
PostPosted: 17:39 - 12 Dec 2015    Post subject: Reply with quote
Bike is running fine, just stalls sometimes.
talkToTheHat
PostPosted: 18:20 - 12 Dec 2015    Post subject: Reply with quote
The one on the carb is an overflow tube. It just needs to run to some still air.
I can't tell from the photos, but the other one is either a crankcase breather or an airbox drain. If it's an airbox drain it should be run to the airbox at one end and be plugged at the other. Unplug occasionally and condensation shall run out. If it it s crankcase breather one end shall connect to the crankcase and the other to most likely the airbox, unless it's supposed to have a breather plug on it. Follow the routing of it. If it's connected to the airbox look for somewhere it's supposed to connect to on top of the crank case. Of course if there already is a tube between the crankcase and airbox it'll be the airbox breather. If so plug it, as you'll be running a bit lean otherwise. A golf tee might work at a pinch. I carry one in my toolbag as it makes a great fuel line plug.
Bandit. does. everything.
Doge
PostPosted: 22:11 - 12 Dec 2015    Post subject: Reply with quote
Thanks alot, will do that.
The last post was made 10 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.1 - MySQL Queries: 13 - Page Size: 43.08 Kb
