| bikertomm |
 bikertomm World Chat Champion
 Posted: 18:12 - 14 Dec 2015 Post subject: What to look for on CBR600f's 2002/03 vintage? |
Asking for a friend,
Searched on here for some pointers and it seems fuel injection is the one to go for.
One thing that popped up that I don't really understand is reg/rec ? How do you check for this?
Courtesy of DrDonnyBrago :
'Rusty downpipes (£170-£300 to replace with stainless)
Noisy CCT - a loud rattle from the RHS of the engine at certain RPM (£60 to replace it)
Dodgy speed sensor - no/intermittent speedo (£120 new, £30 used)
Reg/Rec - they apparently just blow sometimes (not sure on cost, haven't needed one)
Crash damage - lots of people get them as a first big bike.'
So I guess I'll just let him know that.
Now for the bad bit, he possibly wants to fighter it.. which I've already told him would be a crime! But I can only help him get a mechanically decent bike in the first place.
I'd look out for one that's been chucked down the road if I wanted to mess with it, but horses for courses and all that..
Had a quick look and the average going rate for a CBR600F 2000-2003 seems to be like £1700 - £2250 That seems like quite a bit for such an old bike, my hornet was a couple hundred quid more.. (2 years ago!)
One in question is 03', 20k miles. £2k. Good service history.
Or.. any other alternatives for a stunt/fighter that are easy enough to work on? I thought of the ZX6R but again I don't know much about them!
Cheers boys  ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 18:45 - 14 Dec 2015 Post subject: |
I've still got my 2001 model. Had it for 7 years ish (paid £2k, 16k miles and FSH - it was a steal/prices for used bikes have gone up a lot). Most of the problems I've had are covered by your list. Other thing was a leaking radiator I had TIG welded, anything else has been self inflicted or is more of a foible - i.e. The front suspension is a bit soft unless you are a tiny Asian and the pegs can scrape earlier than you expect.
It'd be criminal to fighter a bike with decent fairings and that bike will look particulalry shite defaired. Besides a pretty pants looking frame They have two air ducts running from the ram air openings by the headlight under the tank and into the air box. If you remove the front cowl you still need the ducts, which are slightly floppy plastic things held on by rubber seals. They are a pita to get back in when they come off too.
It is a good bike, but they do hold their money well. If he wants to butcher it suggest something cheap.
https://images5a.snapfish.com/232323232%7Ffp63263%3Enu%3D75%3C%3B%3E237%3E257%3EWSNRCG%3D3344%3A63954348nu0mrj |
| bikertomm |
 Posted: 20:11 - 14 Dec 2015 Post subject: |
Nice one, thanks. Yes this is what I've told him, better off waiting for one that's been binned. But I don't think he wants to wait!
I'll show him that list to check then and he can do what he pleases
Ta.  ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
| bikertomm |
 Posted: 20:18 - 14 Dec 2015 Post subject: |
Is there anyway of knowing if the reg/rec isn't working? Or testing it?
Thanks!  ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
| stevo as b4 |
| DrDonnyBrago |
| stevo as b4 |
| SIG1981 |
 SIG1981 Derestricted Danger
| DrDonnyBrago |
 Posted: 12:06 - 16 Dec 2015 Post subject: |
| stevo as b4 wrote: | It was a 2001 MY CBR600F I tried out, and was nearly brand new and totally standard. I hated it and wouldn't buy one that wasn't fully sorted and set up.
I thought that all CBR's before the 2003RR (the mass centralised one) were carbed engines, except for the Sport model which has FI and a different tail/seat unit?
Both the std Thundercat and ZX6R have lovely engines, and will pull nicely from 2-3000rpm without a glitch to the limiter. The std CBR cannot do this from my experience and also from reading plenty of road tests that mentioned the noise friendly fuck up to the midrange. |
2001+ CBR600f and CBR600f sport are both FI. The sport model had an extra clutch plate, slightly different gearing ratio, a different tail and a few other small things, it has the same Honda PGM-FI system.
I haven't ridden every 2001 CBR600f out there, but I know mine very well. Mine is "standardish" (end can, motad downpipes). Power increases somewhat linearly from 3k to 12k, then tails off as you approach redline. Although it could do with a bit more power low down, there certainly isn't a huge flatspot part way through the rev range. I redlined it up a slip road almost every day for 5 years, I'd probably have noticed.
I'd have to suggest that the one you rode had a fuelling problem. I had a gopping flat spot in the 5-6k range when I had some cheap no-name downpipes, but nothing of note with the stock or motad downpipes. |
| stevo as b4 |
| DrDonnyBrago |
The last post was made 10 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
