Lexmoto Adrenaline 125 - Not Starting
Lexmike
PostPosted: 21:25 - 15 Dec 2015    Post subject: Lexmoto Adrenaline 125 - Not Starting Reply with quote
So my lexmoto adrenaline isnt starting up.
Turn on ignition, Hold in Clutch/Neutral, Side stand up but when i press the starter button nothing happens. ( dont get the clicking noise ).
My lights work but theyre dimmed.
Managed to bump start it and ridden it for about an hour to see if battery would charge but when i turned it off wouldnt start up again.
The battery has a test button and its showing 1/3 bars.
Anyone got any ideas what could be causing it not to start.
J.M.
PostPosted: 21:30 - 15 Dec 2015    Post subject: Reply with quote
Do you have a multimeter?
My first check is always to check what voltage the bike is running with it off and on, though if you've managed to ride for an hour, that implies that you battery is actually charging.
You could attempt to bridge the starter solenoid with a screwdriver, after you turn the power on, to see whether or not that does anything.
2004 R1 & 2018 XSR900
Lexmike
PostPosted: 21:47 - 15 Dec 2015    Post subject: Reply with quote
Havent got a mutimeter no, been trying to get one.
Once ive bumped it it will stay running untill i switch it off then theres no reponse from the starter switch again.
I will try that with the solenoid though, only thing is when im pressing starter switch nothin at all happens, dont get the clicking noise could bridging it still work
cheers
Lexmike
PostPosted: 22:27 - 15 Dec 2015    Post subject: Reply with quote
Tried that with the solenoid, the light turned off and it did make that whirling sound like it wanted to start but barley happend.
331X2
PostPosted: 00:12 - 16 Dec 2015    Post subject: Reply with quote
New battery time Thumbs Up
Lexmike
PostPosted: 19:52 - 16 Dec 2015    Post subject: Reply with quote
Just another thing,
I bump start it with the choke on, once ive bump started it let it sit for 10 mins to warm up. When i go to turn the choke off the revs just keep dropping untill it dies again .
My idle screw is fine, seems weird
331X2
PostPosted: 00:39 - 17 Dec 2015    Post subject: Reply with quote
Ariel Badger
PostPosted: 01:07 - 17 Dec 2015    Post subject: Reply with quote
If your luck is is your battery is potato, if it is bad your charging system is potato.
The last post was made 10 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 54.15 Kb
