| InkedMuttley |
 InkedMuttley Renault 5 Driver
| Taught2BCauti... |
 Posted: 09:45 - 15 Dec 2015 Post subject: |
Check the wattage rating of the bulbs first, then the rating on the flasher relay.
Some flasher relays can work with LED's and Filament bulbs (or a mix) but some need a minimum load to work properly.
A multi-meter set to a 20vDC range, will help test continuity of the wiring. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:51 - 15 Dec 2015 Post subject: |
That's surprising as a relay that works with LEDs should be independent of the load.
Unless the previous owner left a load-based relay in there and put ballast resistors in to make the indicators work.
So:
Find and remove any ballast resistors.
Check that the remaining load from the indicators matches what the relay is designed to work with.
AND/OR
Replace the relay with a load-independent one (but I'd still bin any ballast resistors)
AND/OR
If there's a single indicator idiot-light on the dash, see if there's any shenanigans going on there. Because LEDs are polarity specific, you can't run them both to a single indicator light because of reasons. ____________________ Biking is 1/20th as dangerous as horse riding.
| pdg |
 pdg World Chat Champion
| InkedMuttley |
| Hahadumball |
 Hahadumball World Chat Champion
| V2 |
 V2 Nearly there...
| pdg |
| Hahadumball |
| InkedMuttley |
| Burnzy1989 |
 Burnzy1989 Nitrous Nuisance
| InkedMuttley |
| Burnzy1989 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:27 - 16 Dec 2015 Post subject: |
You have more than one problem. <sic>
Front and back on the same side should always light together. If they don't, it's either a wiring fault or a blown bulb.
Slow flashing usually means too much current draw.
The type of flasher you've fitted are generally pretty very poor quality. I know because I've had several and they required replacing at least once a year.
They also come with a mini 21W bulb which are not the most reliable at the best of times and the ones they come fitted with are the cheapest of the cheap. Usually lasts less than a week.
So.
1) I suspect they are drawing too much current for your flasher relay.
2) I suspect you have either installed them improperly or the units themselves are of poor/intermittant construction.
3) You may have one or more blown bulbs.
The best fix would be to put the original ones back on. Those units you've fitted are NOT an upgrade. They are of questionable value and the only time I'd even think of fitting them is to temporarily fix a crash-damaged bike until funds allow a better solution.
5W dash lights will fit in those housings and should get around the problem of excess current draw (may even make them flash too fast, you can have up to 120 flashes/min), they have got me through MOTs before.
HOWEVER. I would strongly recommend you chuck them in the bin and refit the originals. They are NOT an upgrade and when you come to sell it, anyone who knows bikes will look at those and think "Crashed, fixed on the cheap, probably chopped about the electrics." ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| InkedMuttley |
| Hahadumball |
 Posted: 12:41 - 16 Dec 2015 Post subject: |
 ____________________ Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015 |
| MCN |
 MCN Super Spammer
 Posted: 12:50 - 16 Dec 2015 Post subject: |
Do you think you are funny?  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| InkedMuttley |
| pdg |
| bikenut |
 bikenut World Chat Champion
 Posted: 11:43 - 17 Dec 2015 Post subject: mot |
it didn't even manage half a mile before it hydro locked once more :(
my winter hack passed mot yesterday for the nth time.......so got a ride for xmas day :D
hydro locked again!
brakes locked on??
check the tiny hole in the master cyl, the re couperating port, the port that allows fluid to flow thru the m/cyl when the nipple is undone, by gravity or syphon, cos if this is blocked, then brakes tend to lock on and don't release, also makes bleed the bleed brakes a real pita.
you don't say what bike or which brake :karma:
as to indicators, is the bulb ok, presuming you changed all the led inds to bulb type, get a wiring diagram, a multi meter would be a good thing to get from santa, but you have a "test lamp", 4 in fact, wel 3 that work and one that don't. ____________________ nuts about bikes
| pdg |
| bikenut |
| pdg |
| InkedMuttley |
The last post was made 10 years, 292 days ago. Instead of replying here, would creating a new thread be more useful? |
