any tips to get radiator hose back on.
WULFSTAN
PostPosted: 17:08 - 17 Dec 2015    Post subject: any tips to get radiator hose back on. Reply with quote
While changing a headlight bulb today I noticed that the hose wasn't fully on and I was leaking a bit of coolent. After alot of pushing I can't get it to move any tips to try and get it to budge thanks.
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
Aff
PostPosted: 17:22 - 17 Dec 2015    Post subject: Reply with quote
You have loosened the Jubilee Clip, haven't you?
Electric Bike Project
Err... undo the jubilee clip? Or is that too obvious? Confused
WULFSTAN
PostPosted: 17:24 - 17 Dec 2015    Post subject: Reply with quote
Haha yer I have Thumbs Up
Aff
PostPosted: 17:32 - 17 Dec 2015    Post subject: Reply with quote
I shall assume you took the photo before loosening it then, because it isn't loose in that.
Try giving it a twist, my be crusted on.
Probably just need to MTFU. Wink
PostPosted: 17:45 - 17 Dec 2015    Post subject: Reply with quote
If no exposed electrics you can use boiled water from a kettle or a hairdryer to soften the rubber.
WULFSTAN
PostPosted: 17:49 - 17 Dec 2015    Post subject: Reply with quote
Hairdryer is a great idea thanks bud.
Carvel
PostPosted: 00:09 - 18 Dec 2015    Post subject: Reply with quote
Stop being a pansy
Or
Lift the hose away from the union with a flat bladed screwdriver and spray some wd40 in the gap, then twist it.
monkeybiker
PostPosted: 00:39 - 18 Dec 2015    Post subject: Reply with quote
Just keep wrestling with the bugger until it goes on. Try shouting and swearing at it.
PostPosted: 00:57 - 18 Dec 2015    Post subject: Reply with quote
Loosen the jubilee and slide it out of the way. Now get some pump pliers and gently squeeze and twist the hose right where the jubilee was. This will cause the hose to bunch in front of the plier jaws and break the bond between the hose and the radiator stub.
Just wrenching it about is likely to tear the hose or rip the stub off the rad.
Hahadumball
PostPosted: 10:15 - 18 Dec 2015    Post subject: Reply with quote
loosen jubilee clip, hairdryer to make it soft, bit of soapy slippery stuff and push it on.
job jobbed.
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
sickpup
Old Timer
PostPosted: 00:31 - 19 Dec 2015    Post subject: Reply with quote
That hose looks to me like it is in place perfectly, I suspect the leak is caused by something else.
WULFSTAN
PostPosted: 12:49 - 19 Dec 2015    Post subject: Reply with quote
Correct hose was spilt underneath new hose ordered.
The last post was made 10 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 80.03 Kb
