| prawny1 |
 prawny1 World Chat Champion
| bikenut |
 bikenut World Chat Champion
| 331X2 |
 331X2 Crazy Courier
| chris-red |
 Posted: 12:49 - 18 Dec 2015 Post subject: |
Have you got a strobe? Mark the stator at TDC normally there is some kind of mark on the casing mark tdc in line with that (or put your own mark).
Use a Protractor to mark however many degrees before TDC are required(make) it a different mark so it is easy to see. Then use the strobe to time it to the second mark.
Edit: What lee said! ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| MCN |
 MCN Super Spammer
 Posted: 12:59 - 18 Dec 2015 Post subject: |
If you have the info for the 'static timing' ie Number of Deg before TDC it is possible to find TDC with a pencil.
(It is easier using fabricated tool from the nut of an old plug.)
You poke a rod through the plug nut and turn the engine over until you find TDC where the piston pushes the rod out the plug nut and then the piston moves back down the cyl.. You may need a couple of goes to get the 'feel'.
You then move the rod out the nut in the direction of the piston the measured amount ?º of engine rotation makes. ?mm
Then turn the engine around (in the direction of rotation for the engine. (Do not simply reverse direction as you loose a bit of degrees due to lash.)
Until the piston contacts the rod.
That should be the Static Timing.
You can probably google a better explanation for it and the detail of a fabricated tool. I'll have a shoofti.
My cat is sleeping on my lap and won't/refuses to allow me full range of the keyboard.
This is for a BSA but engine's are engines
https://www.wdbsa.nl/ignition_timing.htm ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
 Posted: 13:30 - 18 Dec 2015 Post subject: |
If you've got a degree wheel, finding precise TDC is easy and needs nothing so inaccurate as a pencil.
You need a piston stop tool. You can make one out of an old sparkplug. Essentially something solid sticking into the combustion chamber that the piston will hit. An old sparkplug with a nut and bolt through it will work, or you can buy a proper one quite cheaply.
https://www.jerrybramlett.net/images/pic_installation.jpg
So attach your wheel. Point your marker to wherever is a convenient fixed point. Insert the piston stop tool and rotate the engine one way until it hits the stop. Note the reading on the wheel and rotate it the other way until it hits the stop. You now have the number of degrees between the two stops. Half that figure and set the wheel to that reading with the piston on the stop. TDC is now at zero degrees.
If I read your initial post correctly though, your biggest problem is deciding exactly when the hall effect sensor is triggered. My uderstanding is it should trigger as soon as the sensor is totally covered. That should at least put you in the correct ballpark to fine tune it dynamically (which could arguably be better done by ear than by strobe anyway).
EDIT: You MAY be able to tell the exact trigger point on a hall effect sensor using a compass. The needle should swing the other way as it triggers
I have a horrible thingy for doing the timing on the enfield by mm BTDC. Essentially a pencil.
https://www.armoursltd.co.uk/wp-content/uploads/00411.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| prawny1 |
| prawny1 |
| MCN |
 MCN Super Spammer
| redeem ouzzer |
 Posted: 18:14 - 18 Dec 2015 Post subject: |
For finding TDC you don't need a timing wheel, just a positive stop.
Screw in the stop, turn the engine one way until the piston touches the stop, mark the flywheel. Now turn the engine backwards until the piston hits the stop the other way, mark the flywheel again.
TDC is mid-way between the marks. This is TDC or 'T' mark. If the two marks you put on the flywheel are a long way apart screw the stop out a bit and do it again - the mark will move closer together.
If it's points ignition and you know the static timing then putting a timing mark on the flywheel is easy. Take the diameter of the flywheel and multiply by 3.142. Divide the result by 360 and multiply by the static advance in degrees. The result is the number of mm around the circumference of the flywheel before TDC you put a mark for the static timing or 'F' timing mark. ____________________ a.k.a 'Geri'
| prawny1 |
 Posted: 21:37 - 18 Dec 2015 Post subject: |
Sounds like it has a crank from a different year then, or a different country. I would cut a new keyway for the woodruff key but that will require some decent engineering. ____________________ a.k.a 'Geri'
| 331X2 |
 331X2 Crazy Courier
| prawny1 |
| Taught2BCauti... |
 Posted: 10:23 - 19 Dec 2015 Post subject: |
I came across a similar problem on another forum, where someone had swapped parts from different model years (Varadero 125). At first glance, the stators looked identical, but on closer inspection, the CPS was 20° out, compared to the original.
If someone has swapped the stator, and it's not the right one for the flywheel, then this could be the reason it's not running right.
If there is a part number on your stator, look it up and see if is the right one for the VIN number - there could be different part numbers for different years. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| redeem ouzzer |
 Posted: 20:06 - 19 Dec 2015 Post subject: |
Lapping a taper is an inherently difficult process. It's easy to ruin both parts and cause them to not grip together at all. ____________________ a.k.a 'Geri'
The last post was made 10 years, 304 days ago. Instead of replying here, would creating a new thread be more useful? |
