two stroke valve adjustment
spottedtango
PostPosted: 03:44 - 21 Dec 2015    Post subject: two stroke valve adjustment Reply with quote
my two stroke needs its valves adjusted....
hohoho
merry xmass!!! Very Happy
weasley
PostPosted: 09:00 - 21 Dec 2015    Post subject: Re: two stroke valve adjustment Reply with quote
hohoho
Reed valves? Power valves? Come on, help us out here.
Dabura
PostPosted: 00:12 - 22 Dec 2015    Post subject: Re: two stroke valve adjustment Reply with quote
weasley wrote:
hohoho
Obviously it's the reverse polarity anti-nitrogen valves that needs doing
Hahadumball
PostPosted: 01:04 - 22 Dec 2015    Post subject: Reply with quote
powerband non return valve
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
wanderinstar
PostPosted: 20:37 - 22 Dec 2015    Post subject: Reply with quote
I fink eez tryin to be funny my ho's need adjustin
Laamapalmu
PostPosted: 16:18 - 23 Dec 2015    Post subject: Reply with quote
Have you checked the crankcase ceiling light? I guess there isn't enough cats in the air filter.
PostPosted: 16:26 - 23 Dec 2015    Post subject: Re: two stroke valve adjustment Reply with quote
Disc valve, schrader valve, oil feed non-return valve, thermostatic valve, needle valve, throttle valve, butterfly valve, choke valve, brake master cylinder valve?
andyscooter
PostPosted: 17:53 - 23 Dec 2015    Post subject: Reply with quote
Don'tthink iI have ever adjusted my tyre pressure valves
bypass2
PostPosted: 20:50 - 23 Dec 2015    Post subject: Reply with quote
Maybe kr1/kr1s kips valves
PostPosted: 09:46 - 24 Dec 2015    Post subject: Reply with quote
You get angled ones that could, conceivably, be facing in the wrong direction.
Hahadumball
PostPosted: 11:15 - 24 Dec 2015    Post subject: Reply with quote
Then hit your brake caliper as you ride off and pull the valve out Brick Wall Brick Wall Brick Wall
pepperami
PostPosted: 12:17 - 24 Dec 2015    Post subject: Reply with quote
OP : If you pull the spongle pins all the way out, the gruddy plates will re-set the whoo valves right good Thumbs Up
spottedtango
PostPosted: 13:46 - 24 Dec 2015    Post subject: Reply with quote
Ive done the spongle pins but I think its the near draft high actuators causing problems in the inlet not allowing enough fuel in.
Ive also rewired my stator/generator to a mini fridge so I can have a chilled drink at my destination Very Happy
Alpineandy
PostPosted: 19:45 - 24 Dec 2015    Post subject: Reply with quote
Is it one of these ?
https://www.youtube.com/watch?v=_ATARLa9d-U
The above comment isn't necessarily the truth and anyone that says it is, is only correct if it's the truth or they're bigger than me.
TehranSD
PostPosted: 21:05 - 31 Dec 2015    Post subject: Reply with quote
Smile))
Very Happy
طراحی سايت
TbirdX
PostPosted: 21:07 - 31 Dec 2015    Post subject: Reply with quote
Sounds like the shim spliven nurbler needs it's wazoo spigot wiggling to me.
Alpineandy
PostPosted: 22:26 - 31 Dec 2015    Post subject: Reply with quote
Wiggling or tightening?
The last post was made 10 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 91.29 Kb
