Speedo stopped working.
Error 650
PostPosted: 20:03 - 22 Dec 2015    Post subject: Speedo stopped working. Reply with quote
Cbr 600 1989. Rev counter works, temp gauge works speedo has stopped working. The cable is in 1 piece so it's either speedo drive or clocks. Is there anyway I can tell which rather than ordering a 'wrong' bit. A second hand set of clocks is about £20 and £15 for a speedo drive. Don't really want to be stuck with a replacement working part.
Dav1son
PostPosted: 20:08 - 22 Dec 2015    Post subject: Reply with quote
This bike isn't doing so well at the moment is it.
I am gonna guess the speedo runs off the front wheel?
Start by removing the wheel and drive. Turn the cable and check what speedo does.
If it works, its the drive.
If it doesn't take the cable off at the clocks and turn it again, if the top turns the cable is in one piece, its the clocks.
But I would guess at the cable.
Future: ....
Present: GSXR-750 L0
Past: ZX10R C2H, TL1000R, CBR400 NC29, GPR50RR/RS50
Snod Blatter
PostPosted: 21:03 - 22 Dec 2015    Post subject: Reply with quote
I would remove the cable from the speedo drive and roll the bike forwards a bit to see if the driving tab turns round Thumbs Up
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
Error 650
PostPosted: 21:18 - 22 Dec 2015    Post subject: Reply with quote
Thanks both of you, good tips there. I shall have a go tomorrow.
yen_powell
PostPosted: 23:02 - 22 Dec 2015    Post subject: Reply with quote
If the cable is still in one piece it's probably going to be the white nylon gear inside your wheel, they wear out and stop spinning the cable. You can pack them out with a washer so an unworn bit makes contact until you can get a new one.
XT1200Z and a DR350 in bits
Error 650
PostPosted: 18:58 - 23 Dec 2015    Post subject: Reply with quote
Ok fixed this. It was the cable. It was in one piece but was ceased. New cable in place and all is good.
I raised the front wheel with a borrowed front micron stand and span the front wheel and the connector on the drive span. Reattached the cable and the cable did not spin. New cable span whilst attached to the wheel and once attached to the clocks it worked perfectly.
The last post was made 10 years, 284 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.41 - MySQL Queries: 13 - Page Size: 51.63 Kb
