| Blunet600 |
 Blunet600 Nearly there...
| Rogue_Shadow |
 Rogue_Shadow World Chat Champion
 Posted: 22:27 - 23 Dec 2015 Post subject: |
I'm surprised to hear that "no one else" is being affected by this, as REIN faults cause issues indiscriminately within the vicinity of the faulty equipment. So if this is REIN, the problem is independent to you, such as your telephony cable running in a different location to the rest of the flats or not in the correct trunking.
How has this been proved to be a REIN issue? Has a REIN specialist visited the site and confirmed the faulty equipment, or has a standard Broadband training engineer made the "diagnosis" ?
4 engineers, so I imagine one of them has fitted a VDSL/SSFP front plate.
https://bt.custhelp.com/rnt/rnw/img/enduser/ssfp_socket.png
These plates (In MK3 form, check the top right corner) have a basic radio frequency filter than can alleviate the issues of REIN but not a substitute for removing the source or complete isolation from it. |
| iooi |
 iooi Super Spammer
 Posted: 23:09 - 23 Dec 2015 Post subject: Re: REIN affecting internet connection - Can anyone help? |
| Blunet600 wrote: | the 4th engineer out of which was a bt engineer found that the lift in my block was causing REIN when ever it was in use and cutting out my internet/broadband.
It sounds like this might be a long fix judging by what sky and bt have said. . |
| Quote: | Typical REIN sources
This list is not exhaustive but known and common culprits are:
Faulty thermostats (Central heating, Immersion heaters).
Electrical power supply units (Laptops, Routers, Plasma, TVs).
Decorative electrical items (Christmas tree lights, Touch lights).
Digital Communication Receivers (Satellite and Freeview set top boxes).
Security systems (PIR lights switching on and off).
Fluorescence Lights & Faulty Street Lights
Powerline Adapters & Treadmills
Industrial/Commercial power usage (Electric Railways, Electric fences, Electric motors).
Internal power cables and telecom cables running close together.
A current imbalance between two power carrying conductors (Earth leakage fault)
Read more: https://www.kitz.co.uk/adsl/rein.htm#REIN_fault#ixzz3vBTQcBbw
Surely that would be a issue for the management company to resolve with the lift company.
I would have though that if it was the lift, then your connection would be dropping a lot.
TBH. pop over to Think Broadband Great for this sort of thing. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Blunet600 |
| Rogue_Shadow |
 Posted: 23:52 - 23 Dec 2015 Post subject: |
SFI Engineer, which is a standard broadband engineer.
So long as that engineer passed on all the details to the REIN team, hopefully it will progress for them to arrange a visit.
Once the REIN team actually identify the specific offending equipment, they will inform the owner that it's causing issues.
Unfortunately beyond that, they cannot force the the repair
So pile on the pressure to your service provider who will in turn pressure Openreach to commit the REIN team to the problem.
Unfortunately you cannot contact Openreach directly, so it's down to your service provider. If this seems to be going nowhere, contact your local MP ... " As a constituent you are disgusted by the delays" ect.
You have two frequencies traveling down the copper pair to your socket, a analogue frequency and a digital frequency.
REIN affects the digital / broadband signal that your modem router needs to establish a internet connection, basically by corrupting the digital signal before it reaches your router. The broadband equipment can deal with a small portion of REIN, but often at the cost of the download speed, so some people maybe blissfully unaware of an issue. However If REIN is frequent/intensive enough it will distort the signal to the extend that the modem can not longer maintain a reliable connection causing a disconnection.
With multiple disconnections, the broadband equipment in the exchange (or the street if your on fruit'n'fibre) will evaluate the line and will likely reduce your max attainable download speed in a bid to provide you with a slow, yet reliable service.
Your Sky hub wants a cup of Tea, but REIN keeps adding too much water!
https://2.bp.blogspot.com/-T2xcDY0i7v0/Th3IClFtK4I/AAAAAAAAA3w/KgrjjlDKG60/s1600/teamaster.jpg.png |
| anthony_r6 |
 anthony_r6 World Chat Champion
 Posted: 11:07 - 24 Dec 2015 Post subject: |
How hard/expensive would it be to run your own bit of shielded cable up to you from wherever the lines come into the building?
Not sure what the setup is in your building but if it's a smaller building where you're not going to get grief off a concierge and it's all in conduit, it's not necessarily a big or hard job.
You can get 100m reels of shielded, twisted-pair cable for £50 or so.
Or can you get 4G and sack the broadband off altegether? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Taught2BCauti... |
 Posted: 12:05 - 24 Dec 2015 Post subject: |
A mate of mine had a problem with his broadband, shortly after the electric company installed Smart Metering in his apartment block.
The signal came in on a 4 pair STP cable, but there was no continuity between the shielding and the building's electrical earth, so I connected the shield to the earth of an adjacent power socket.
This didn't fix it completely, but did make a significant difference to the number of dropouts. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
The last post was made 10 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
