Nsr won't idle!
Tristan_NSR
PostPosted: 01:11 - 24 Dec 2015    Post subject: Nsr won't idle! Reply with quote
Recently decided to buy myself an nsr 125, have currently gone through a top and bottom engine rebuild, was running lovely and then I had problems with my starter motor either not working or staying stuck on and a couple days into this problem my bike now refuses to idle at all and seems like there is not grunt in the lower revs, I have to keep it at 2k just to keep the little cow running! If anyone has experienced this or knows anything then all your help would be vastly appreciated! Thanks👍🏻
TcNsr
PostPosted: 11:16 - 24 Dec 2015    Post subject: Reply with quote
Blocked Idle circuit clean the carb jets out.
Tristan_NSR
PostPosted: 11:24 - 24 Dec 2015    Post subject: Reply with quote
I had my carb cleaned by a garage less than two weeks ago..
TcNsr
alains
PostPosted: 12:02 - 24 Dec 2015    Post subject: Reply with quote
check the choke piston and the cable
Under the choke is a robber bit which close the air passage and it could be worn (look dellorto site for 28PHBH spares change piston and spring)
also if the cable is dirty or with sharp bends it may make the choke stocked
if your starter get stocked it has nothing to say with the carb , so check the starter relay then your starter itself
download https://www.geneva-racing.ch/~alains/NSRtips.doc (~5Mo) and follow instructions on starter rebuid
any spares are avaiable at davidsilverspares.co.uk (brushes & springs)
The last post was made 10 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 39.02 Kb
