Indicator HELP
rizo9
PostPosted: 12:00 - 12 Feb 2005    Post subject: Indicator HELP Reply with quote
i have an rs125 (2001)
just pluged in new spear shaped indicators, it works fine when one indicator is in but when you plug both in it makes a wierd noice. and dont flash,
what is wrong?
New bike Very Happy https://www.bikepics.com/members/rizo9/01rs125/
BlueNinja
PostPosted: 12:30 - 12 Feb 2005    Post subject: Reply with quote
Double check your wiring. Use insulating tape and cable ties to keep things tidy, and check the indicator relay. This is a small black box, about the same cubed area as a match box. This has a cover on it, which you can usually remove and check the relay contacts. If in doubt, have a garage look at it.
Big Kawasaki ZXR 400 project here:
https://www.theundertaking.com/index.php?showtopic=483
Mr.Everready
PostPosted: 13:16 - 12 Feb 2005    Post subject: Reply with quote
what is the weird noise ?
If its fast clicking it will be a loose connection or maybe a blown bulb.
rizo9
PostPosted: 13:57 - 12 Feb 2005    Post subject: Reply with quote
i have been told that my relay is not the right wattage? would this be right?
kasandrich
PostPosted: 14:03 - 12 Feb 2005    Post subject: Reply with quote
The relay has to be the right wattage for the bulbs.......now, I reckon you are probably fitting the LED type indicators?
If so that'll be the cause as they are very low wattage, so they don't put the right load on the relay, .......they don't tell you about these things when they sell you the indcators do they?
Richard
CBR1000FM
Noggin
PostPosted: 14:04 - 12 Feb 2005    Post subject: Reply with quote
When i changed the indicators to micro arrows on my nsr, I had to change the relay box because the power rating (watts) were wrong. My indicators flashed really fast, thats why i changed it.
Craig G(Noggin)
Current bike: kawasaki zx12r 2002
Track bike: yamaha r6 1998
Old Bike: honda NSR 125 1998
rizo9
PostPosted: 14:05 - 12 Feb 2005    Post subject: Reply with quote
i think standard bulbs are 10Watt and the new ones are 20watt
where can i get the right relay from?
and where bouts is it?
iheartpie
PostPosted: 14:24 - 12 Feb 2005    Post subject: Reply with quote
contact the manufacturer for appropraite bulbs, they will be wrong wattage.
brooooom, BROOOOommmm
https://www.mrnathan.cjb.net
jamie192
PostPosted: 14:34 - 12 Feb 2005    Post subject: Reply with quote
ok wait dont listen to any of them, if your relay is not sealed there is a simple fix, all you have to do is bend the armature a little, and it will work, i know it works because its been done on 3 bikes and they have all worked and still do.
Ride Fast, Brake hard, don't fall off!
The last post was made 21 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 58.3 Kb
