| Gazz |
 Gazz World Chat Champion
| doggone |
 doggone World Chat Champion
 Posted: 15:26 - 26 Dec 2015 Post subject: |
There will be a small header tank and it will probably top itself up from the mains, however if it's some kind of modern pressurised system I'm clueless.  |
| reckless_b |
 reckless_b Trackday Trickster
| Skudd |
 Skudd Super Spammer
| Andy_Pagin |
 Andy_Pagin World Chat Champion
 Posted: 15:42 - 26 Dec 2015 Post subject: |
From memory - and no responsibility accepted if it goes horribly wrong!
Assuming a modern combi system.
Switch off/unplug the boiler.
Somewhere downstairs there will be a drain tap, usually on the hall radiator pipe. Stick a hose on it and poke outside the front door.
Close all the valves on the radiators you are not draining.
Open the drain tap.
Open the air vent on the radiator you are changing.
Let the system drain till nothing, or just a trickle come out of the hose.
Close the drain tap.
Close both taps on the radiator to be removed.
Stick a bowl under one of the radiator pipes and carefully unscrew it.
The water will be filthy, so take care.
Do the same the other end.
remove radiator.
Fit new one using ptfe tape.
Open both valves.
Under the comb there is a filler valve which may or may not have a pipe connected to a mains inlet (plumbers are supposed to remove it but often don't). Assuming the pipe's connected open the filler valve, switch on the boiler, let the gauge get up to just over 2 Bar, close the filler valve.
Go upstairs and open the air vent on the new radiator, air hisses out as it fills, close the vent as soon as water dribbles through.
Open the valves on the other radiators.
Back to the boiler, fill once again to get back to 2Bar.
Job done. ____________________ They're coming to take me away, ho-ho, hee-hee, ha-haaa, hey-hey,
Yamaha Vity -> YBR125 -> FZS600 Fazer -> FZ1-S Fazer |
| Gazz |
| iooi |
 iooi Super Spammer
| Robby |
 Robby Dirty Old Man
| Al |
 Al World Chat Champion
 Posted: 17:22 - 26 Dec 2015 Post subject: |
If the system has a small header tank it will self fill, you just need to open the radiator valves when the new one is fitted and vent any air out of the radiator.
It will be the same process to fill a sealed system although rather then the header tank refilling the water that has been taken out of the system, you will need to manually open a filling valve, normally on or around the boiler or sometimes in an airing cupboard to top up the lost pressure.
That is assuming that the radiator is an identical size and a straight swap as well as both radiator valves not being seized, if so you will need to drain the system down or at least get a vacuum to work on the pipework. ____________________ Yamaha FZR400RR 3tj
My Instagram Thingy |
| MCN |
 MCN Super Spammer
 Posted: 12:00 - 27 Dec 2015 Post subject: |
If you are fitting a new rad then you may as well flush the system before you fit it.
It only takes an hour to drain and fill with fresh water and put a cleaner in.
If it's a header tanked system simply turn off your cold water at your mains. This prevent the header tank filling via it's ball cock.
Locate the drain cock/s and attach a garden hose to the drain cock spigots.
Open the heating system drain cock/s 1/4" spanner or a wee shifter.
Open the drain cock/s and let the system drain.
If the water is black then you have no inhibitor which is bad as it means the water will be eating the radiators and the boiler.
The sediments produced by this action settles out and can restrict water flow, reducing heating effect and mean the boiler has to work harder to get heat into the house.
Fit your new radiator.
Close the cock/s.
Add a system cleaner.
Open the mains and let the system fill.
When it's full bleed the air out the radiators.
There may be a bleeder above the boiler to open too depending on the layout/plumbing.
Start the system and let it warm up.
Check your connections on the new rad for leaks.
Let the cleaner 'work' in the system for and hour or more or a few days and then drain it down again as before.
Fill and bleed and run for about an hour then drain and fill again.
The water will still be black/grey/dirty for a couple of flushes.
When you see the water is clear.
Close the cocks.
Add inhibitor and fill and bleed.
Run the system to circulate the inhibitor.
You can add boiler silencer too which helps prevent the boiler 'creaking' due to steam bubbles.
It is a good time to upgrade the bleeder to automatic ones while the system is drained.
A clean system will work better and using less fuel to heat the water will help pay for the additives.
I only use Fernox products and it costs about £50 to flush and treat an average sized system. Chemicals
If you have a pressurised system you will need to buy a 'filling loop' if there is not one already fitted.
This allows you to connect main water pressure to the heating system accumulator to fill and 'pre-charge' the system to about 1-1/2 bar.
The connection to mains must be removed to prevent the system polluting the mains when not being used to fill.
You can buy a piece of braided hose with crimped connections from B&Q for a few £s.
Buy a new drain cocks before opening the system.
The rubber seats can harden and will fail when opened.
You can sometimes escape by just replacing the core/stem from the new cock rather then having to replace the whole McGubbens.
That may be easier if your cock is soldered to the system.
This job is a summer time job.
There are companies who sell this service but the better job is when they attach a power flusher to the system (external high volume pump) and even bettererer some of them attach a vibrator and vibrate the radiators while the flushing pump hammers water around. They use a magnetic filter to hold the iron deposits whilst circulating which saves water and lets the client go Whaao... when they open the filter and show you all the iron stuck to it.
£400-£500 or more per average hoose ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Tarmacsurfer |
 Tarmacsurfer World Chat Champion
 Posted: 13:51 - 27 Dec 2015 Post subject: |
It'll be piped up something like THIS.
Backboiler systems are never sealed, they have to be able to vent in case of overpressure. There will be two, possibly three tanks in the loft, an indirect cylinder that stores hot water (there will likely be four pipes running into in, a feed off the stove into the side around mid way up that goes into a copper coil, a cold water feed into the side near the bottom and then a pipe at the top which carries hot water out to your taps).
There will also be a smaller header tank with an open top for the radiators that has a ballcock fitted, it'll refill itself as necessary from the main feed.
If you have a private supply such as a spring (like our place) then you'll definitely have a third large tank, open topped and containing cold for the system. Even if you're on a mains feed then you'll likely have one anyway as a feed for the header and hot water cylinder.
Two points, there's no guarantee there will be a drain point - I've seen many systems that were put together without for whatever reason. Christ only knows what the builder was thinking. And as others have said, it's probably worth flushing the system and refreshing the inhibitor. Check over your pump at the same time.
Edited for clarity - Two tanks, one cylinder. Not three tanks. One header for hot water cylinder, one header for heating, one heating cylinder. ____________________ I'm immortal. Well, so far. |
| mentalboy |
 mentalboy World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 16:22 - 27 Dec 2015 Post subject: |
And..... As Tarmacsufer suggests, hoi the pump off and clean out the impeller.
If the system has been neglected/minimal maintenance (as most are and folk worry about boiler maintenance insurance ) you can find little bits of detritus get caught in the vanes of the impeller. This builds up until it blocks the flow of water through the vane which causes a hydraulic imbalance in the pump and the pump will vibrate like a bastirt. You should not be able to hear the heating when it is running.
If you can hear water gushing through the rads it may nee the 'lock shield' valve adjusted slightly.
But that is another adventure. Balancing the flow.
A bit like Bandit carbs. Can be a skoosh case if everything is working but a beeatch if a valve is bad.
But a very therapeutic exercise and when balanced your system will sing (but into it's self, so you cannot hear it.) ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
The last post was made 10 years, 305 days ago. Instead of replying here, would creating a new thread be more useful? |
