Is this a pressure coolant leak?
evilzed
PostPosted: 19:53 - 28 Dec 2015    Post subject: Is this a pressure coolant leak? Reply with quote
About 2.8k miles back I topped up my reservoir to the full line as it was only slightly down. Today I noticed the coolant was on the lower mark and saw this mess and am wondering is this a bad piece of hose probably?
The bike is a Suzuki Inazuma 250 while the rad has a fan I've only seen (can't hear it like bigger bike fans) it run once so assume being a small engine it very rarely gets hot which is why there hasn't been that much coolant loss over the miles covered. Also there's no visible leaks anywhere when I spotted this so am assuming it's under pressure only.
Anyone know for sure?
https://i.imgur.com/1I0BMWc.jpg?1
Snod Blatter
PostPosted: 21:45 - 28 Dec 2015    Post subject: Re: Is this a pressure coolant leak? Reply with quote
Not a chance, you're the one with it in front of you! I'd be more suspicious of the plastic neck above it than the hose, can you take it off to look for cracks? Or perhaps the cap is faulty and it's spewing out past it?
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
evilzed
PostPosted: 23:30 - 28 Dec 2015    Post subject: Reply with quote
I'm going to clean up the hoses and tighten them up a little and see what happens, I can't see any cracks on the neck. Might need to get my hands on a pressure tester if it carries on after tightening.
evilzed
PostPosted: 00:55 - 29 Dec 2015    Post subject: Reply with quote
Apologies for the double post but I thought I'd just add the solution. After browsing bike specific forums it seems like it's an assembly thing and common leak for these bikes, the upper hose just needs nipping up. The manual recommends tightening the clamps at 1.5NM which I thought was interesting too.
The last post was made 10 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 39.81 Kb
