Sprocket wear - non motorcycle
Northern Monkey
PostPosted: 12:33 - 30 Dec 2015    Post subject: Sprocket wear - non motorcycle Reply with quote
This sprocket was made in 1927 by stuart kerr, and I'm working with a team who are rebuilding the something back to original spec.
Do you think that the wear on the teeth is acceptable, with a little file dressing, or does it look like it needs to be replaced.
I have the original drawings, but there is no indication of maximum allowable wear to remain in spec.
It's approximately 400mm diameter, and 35mm thick.
https://img.photobucket.com/albums/v284/geoffhill/9B4FDE04-0E1C-408D-906F-CDEB0EE67B88_zpshxgakwvl.jpg
https://img.photobucket.com/albums/v284/geoffhill/859FDF6E-6BA7-4992-8323-9119885C7D0F_zpsm0gtygf5.jpg
https://img.photobucket.com/albums/v284/geoffhill/64AD6C96-4FDA-4282-B9BF-1610D2A54779_zpsddtagd77.jpg
https://img.photobucket.com/albums/v284/geoffhill/B18418E2-28B1-4B6E-9B6A-96CB118717E6_zpsbfdnhizo.jpg
lihp
PostPosted: 12:37 - 30 Dec 2015    Post subject: Reply with quote
Seen worse on JizzBunnies bikes
Northern Monkey
PostPosted: 12:39 - 30 Dec 2015    Post subject: Reply with quote
One of the options it to build up the wear on the teeth with weld then re-machine, but I didn't want to use 'welding a sprocket' as the thread title
jimspeed
PostPosted: 12:47 - 30 Dec 2015    Post subject: Reply with quote
The splines look pretty battered too.
What does it drive? If you have the drawings how does it compare to those ?
Interesting stuff I love old machines
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
PostPosted: 12:58 - 30 Dec 2015    Post subject: Reply with quote
You may well find it's as easy to just get a new one.
They were using pretty standardised chain pitches in the 1920's and 30's. Bicycles were invariably on 3/32" or 1/8 x 1/2" pitch, just like modern bikes. Bigger chains were usually 5/8" x 3/8" or similar*.
I'd measure it up and see. You can probably buy a blank sprocket of the correct size and pitch, then it's just a case of milling the splines which, given you have the original to use as a template, should be a doddle for a competant machinist.
There's being original and then there's taking things to an extreme. You wouldn't run a model T ford on it's original tyres and brake linings. A sprocket is a wearable part, I assume you're not using the original chain if it was running on that sprocket. It's also the only one you have with the original spline dimensions.
My advice would be to keep that one for a reference template before it wears further or breaks (it's fairly pitted) and use a new one.
I also reckon it would come up nicely with electrolytic rust removal. But you will also see how badly pitted it is.
*5/8" x 3/8" is the same as the 530 chain fitted to most sports bikes.
Northern Monkey
PostPosted: 13:00 - 30 Dec 2015    Post subject: Reply with quote
Google Kerr Stewart 4415. It goes on the gearbox output spline. The drawings are very high res TIFFs, so I can email if you want
PostPosted: 13:09 - 30 Dec 2015    Post subject: Reply with quote
Can I assume that sprocket is much, much bigger than it appears in the pictures then?
Usual BCF half-a-story shite strikes again.
Even so, look at the availability of commercial blank sprockets. Industrial drive chains and conveyors are constantly wearing out.
1" and 1 1/4" pitches are common.
Northern Monkey
PostPosted: 13:15 - 30 Dec 2015    Post subject: Reply with quote
Size is in the original post. It's 35mm thick and 400mm in diameter. It is sized for 2 inch pitch chain which I'm trying to locate today
If I were to replace it, it would be water jet cut hardox 400
PostPosted: 13:34 - 30 Dec 2015    Post subject: Reply with quote
If I were to replace it, it would be water jet cut hardex 400
Embarassed
My appologies.
You'll get one that's close enough off the shelf.
A very quick google shows Tsubaki make one that's 2" x 1 1/8" (part no: 160A13). Pretty close and that means the chain will be available off the shelf too.
What's on the other end? (EDIT: Beat me to it)
Northern Monkey
PostPosted: 13:39 - 30 Dec 2015    Post subject: Reply with quote
Vincent wrote:
Yep.
It's sat on a plinth in Mauritius for 40 years, after being worked into the ground, so it's a bit rough
Northern Monkey
PostPosted: 13:44 - 30 Dec 2015    Post subject: Reply with quote
https://img.photobucket.com/albums/v284/geoffhill/KS33272_Sprockets%20-%20Copy_zpszrnjkfm0.jpg
Northern Monkey
PostPosted: 13:51 - 30 Dec 2015    Post subject: Reply with quote
Rather embarrassingly, the drawing clearly states 2 1/2 inch, not 2 inch
PostPosted: 14:08 - 30 Dec 2015    Post subject: Reply with quote
The roughness on the teeth would worry me a bit more, from the wear that will do to the chain (and how rapidly they will wear away anyway). As mentioned earlier the splines look a bit worn as well.
However I think I would want to know the costs of making a new one.
Katy
MCN
PostPosted: 15:10 - 30 Dec 2015    Post subject: Reply with quote
Sprocket is gubbed and not worth refitting.
An engineering shop can make a new one/two.
You need to find a specialist who cut gears and such.
If you speak to your local engineers they may know exactly who can do it.
I had to make a double helix hypoid-esq pinion and crown set for a 1960s 120HP 90º drive one day.
There were only two places in Europe who could cut them as the design was American and there weren't may places in Europe made American gears. Smile
I had originally asked my engineering mates and it was them who sorted it all out.
I think the job cost about £20k but there were NO new parts and NO 2nd hand stuff and a big rig was stood doing nothing waiting for a 90º drive. Shocked
As far as Restoration Projects go:
It may not be cheap but it will be worth it.
The bastirt is 'always' in the detail.
PostPosted: 17:05 - 30 Dec 2015    Post subject: Reply with quote
IF I had to get that made I'd elect to waterjet the profile then turn the taper on the teeth and hand-finish the splines. Might even be able to laser 1 3/8" plate nowadays.
Northern Monkey
PostPosted: 21:51 - 30 Dec 2015    Post subject: Reply with quote
Looks like the chain is fairly standard stuff. It's ISO r606 40b1 63.5mm simplex chain. Which is just off the shelf, but for more than £1000 per 5m length Shocked
https://www.hoyertransmissions.com/?id=30208&show_product=1&action=detail&pid=0600401000
If the chain is off the shelf stuff, then getting a 13tooth sprocket should be fairly simple, and I can just machine the centre aperture and splines on the mill
The last post was made 10 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 109.33 Kb
