Fairing plastic?
jamie192
PostPosted: 14:36 - 12 Feb 2005    Post subject: Fairing plastic? Reply with quote
Does any body know what type of plastic fairing for a motocross would be made out of and where i could get a sheet of it from?? thanks!!
Ride Fast, Brake hard, don't fall off!
slowarse
PostPosted: 16:21 - 12 Feb 2005    Post subject: Reply with quote
i don't think you can get it in sheets, fairings are usually injection moulded!!!
what do you need it for??
mchaggis
PostPosted: 16:38 - 12 Feb 2005    Post subject: Reply with quote
If it's for a patch repair, glass fibre and resin is the usual way to do it as far as I am aware. If it's a crack, 'plastic soldering' is the usual way to bodge it back together.
I must not be a troll...
Mmmm, Guinness
jaffa
PostPosted: 16:50 - 12 Feb 2005    Post subject: Reply with quote
Duplicate - how did that happen - it said error at my end.
jaffa - all juice and no pips
jaffa
PostPosted: 16:57 - 12 Feb 2005    Post subject: Reply with quote
Look for a recycling symbol on your other parts, it'll probably be a triangle made of of three arrows with letters in it, the letters denote the material (pp-polypropylene, pc-polycarbonate etc).
Most plastics used in injection moulding are available in sheet form often in various colours, look for engineering companies that make plastic parts. If you only want a small sheet you can buy small sheets of common plastics online from RS Components https://rswww.com, look under mechanical -> engineering materials -> plastic stock -> engineering plastics
jamie192
PostPosted: 21:30 - 12 Feb 2005    Post subject: Reply with quote
I want it cuz my friend, a clever guy said he would remake the back end on my ts 50 x and he has left getting the plastic up to me :s. but im hoping to find like the bak end of another one then just fiddle around with it and make it fit instead of making it from scratch. thanks for your replys
The last post was made 21 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 47.28 Kb
