| Paul smifff |
 Paul smifff Renault 5 Driver
| Jewlio Rides Again LLB |
 Jewlio Rides Again LLB World Chat Champion
 Posted: 17:29 - 27 Dec 2015 Post subject: |
Mr Haynes ____________________ Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems |
| Paul smifff |
| andys675 |
 andys675 World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 23:08 - 28 Dec 2015 Post subject: |
| Paul smifff wrote: | You are welcome to enlighten me with the information with in one but I can only seem to find Haynes for 50cc mopeds. I was hoping for something more specific. |
Isn't the Peugot Luddite whatever a 50cc moped?
All refs I see seem to suggest so... and that ts a water-cooled two stroke.. which probably implies its a minarelli engine if you want to do a bit more research... Or stop being a cheap wad and buy the book... if you cant afford £20 for the manual, then you cant afford to run even a chippy-ped FFS!
However... its a two-stroke and its a 50... it ought to have some compresion, but if you try measuring it, you are unlkely to get any meaningful numbers, cos its got a tiny pot with bludy great holes in the walls, and a combustion chamber so tiny, removing the spark plug and pushing in a push-fit compression tester probably doubles it, IF it even seals half decently!
I'd go by the old rule of thumb... if you hold your thumb over the plug hole and give it a good kick (or spin on the e-start) throttle wde open so it can drag in something to squash, and it makes farting noises pushed past your thumb... its probably got enough compression to run... if not probably not.
Beyond that, if you want t know what state the motor is in, you may as well cut to the chase & take the top off and have a look.. all it needs is a new head-gasket. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Paul smifff |
 Posted: 09:22 - 30 Dec 2015 Post subject: |
Thank you to those giving a sensible answer.
The compression test has come out at 34 which is very low. I performed the test as I would on a 4 stroke assuming the tests are done the same way.
Next job take the engine out and take the head off  |
| Paul smifff |
 Posted: 20:59 - 02 Jan 2016 Post subject: |
OK so all apart. Piston has a piece missing with a broken ring and a groove in the cylinder wall.  |
| Old Git Racing |
 Old Git Racing World Chat Champion
| Paul smifff |
 Posted: 22:43 - 02 Jan 2016 Post subject: |
I'd upload a picture for people's opinion but I'm not sure how?
Looks like something got in there due to the damage. Possible that it seized, broke a piece of the piston and fired that around until it rolled to a stop. I need to check to try and find pieces in there somewhere to try and prevent further damage.
I was contemplating put the 70cc bore and piston in but think setting it up may become a ball ache. Maybe just best to stick with standard sizes.  |
| Paul smifff |
 Posted: 18:33 - 07 Jan 2016 Post subject: |
Ordered
New head
New bolts
New thermostat
70 cc piston and cylinder kit
Small end bearing
| evoboy |
 evoboy World Chat Champion
 Posted: 21:37 - 07 Jan 2016 Post subject: |
| Paul smifff wrote: | Ordered
New head
New bolts
New thermostat
Small end bearing
If its one of those cheap £40 70 kits off ebay dont expect much. They are just a bored out stock cylinder and they hate revs. If its a quality kit then itll run poorly on the stock exhaust and carb.
Cant really win.  ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| Paul smifff |
 Posted: 17:45 - 08 Jan 2016 Post subject: |
Well..... that sounds disappointing lol.
Thought it'd be interesting. I bought it all from racing planet but will report back on quality. I have a technigas exhaust and will rejet the carb. Hopefully I'll see a bit more pull on hills  |
| Paul smifff |
| Paul smifff |
| sickpup |
 sickpup Old Timer
| Paul smifff |
| evoboy |
 Posted: 23:56 - 21 Jan 2016 Post subject: |
Shouldnt need 3 base gaskets. They normally come with 3 metal gaskets and one paper one. The paper one being the most used on a basic setup.
Wouldnt bother with the CDI. They do nothing. My Minarelli AC scoot runs at 11000rpm through the revs with the standard ignition setup. Pulls wheelies and will nudge 70mph.
The Naraku kit isnt a bad kit nor what I described as an ebay special, but depending on what Technigas pipe your running it may not work so well with that cylinder.
The flat spots will be the gearbox setup.
If your running the stock carb, it may well be a 12mm one ( not clued up on what Peugeot used on that scoot ) and will be ok for 50mph, but anything more will need a 17.5mm carb. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| Paul smifff |
| Paul smifff |
| Nobby the Bastard |
| Paul smifff |
| chris-red |
| Paul smifff |
| Paul smifff |
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
The last post was made 10 years, 247 days ago. Instead of replying here, would creating a new thread be more useful? |
