Aftermarket indicators
robboadd
PostPosted: 20:02 - 11 Feb 2005    Post subject: Aftermarket indicators Reply with quote
I've just bought a sachs xtc125 2001 the previous owner fitted some aftermarket rear indicators and he told me that they didn't workj properly but are easy to fix. I can't remeber what he said so can you help me out? When you switch the indicators on say on the left they go on but don't blink i don't have a clue what to do!
Thanks Adam
Flip
PostPosted: 20:17 - 11 Feb 2005    Post subject: Reply with quote
Think it's something to do with the wattage of the bulbs.
Do a search and you'll find loads of posts lurking around here to help you out. Thumbs Up
Scotsman37
PostPosted: 20:23 - 11 Feb 2005    Post subject: Reply with quote
There could be a fault with the bike's turn signal relay unit as it's supposed to alternate the power on/off to make the indicators flash, either that he has wired the aftermarket indicators around the wrong way round. There should be a wired connection block located just under the bike's seat so try swapping the wires around that connect from the indicators.
Every indicator comes with a basic foot or so length of wires from it with a connector on the end. so just follow the wiring from the indicator till you reach the connection and swap around what wires that connect to see if it makes a difference. If it doesn't, then a closer look at the signal relay unit is required for a possible fault.
robboadd
PostPosted: 18:39 - 12 Feb 2005    Post subject: Reply with quote
ok i'll give that ago when i have sometime its the last job it needs doing until the MOT wayhey!!!! Well i hope it is! thanks
Whitetrash This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 21 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 42.96 Kb
