Bandit 600 MK2 Milage Altering
BenCooke
PostPosted: 12:04 - 04 Jan 2016    Post subject: Bandit 600 MK2 Milage Altering Reply with quote
Hi,
I'm buying a Suzuki bandit 2000 Reg MK2, the bike has had 5 owners and apparently has 13000 miles. I'm just wondering if the mileage could have been altered as 13000 miles is very low for a bike of its age and for the amount of owners its had. If the mileage can be altered is there anyway I can check this?
Also while I'm on, can someone give me some information on what I should be looking for that could be knackered?
Cheers.
Ben.
b.cooke
chrisdubya
PostPosted: 13:06 - 04 Jan 2016    Post subject: Reply with quote
Try and find its MOT history, all mileage is logged on there. It can be viewed online, but you might need the V5 number
Matt B
PostPosted: 13:34 - 04 Jan 2016    Post subject: Reply with quote
In b4 the "Don't trust a low mileage bike" brigade.
The bike is 15 years old, so that means a new owner every 3 years and a bit under 1k miles per year. IMO that is not particularly unusual or anything to worry about as long as you verify the mileage through the service history/receipts/MOTs. As said, you can check MOT history online but it may not show all recorded mileages for each year.
Take a look anywhere there are bikes for sale and you will find many bikes around that age with similar mileage.
BenCooke
PostPosted: 15:52 - 04 Jan 2016    Post subject: Reply with quote
Thanks for replying I will see if I can find it MOT history online, the seller assures me he has a lot of paper work including past MOT's. Thanks lads!
b.cooke
BenCooke
PostPosted: 16:01 - 04 Jan 2016    Post subject: Reply with quote
Just checked it there and the MOT history and milage checks out! thanks for the advice!
b.cooke
hmmmnz
PostPosted: 00:18 - 06 Feb 2016    Post subject: Reply with quote
my 98 mk1 has 16000 miles
so less than 900 miles a year.
roughly the same as yours,
https://www.gov.uk/check-mot-history
the humans are dead
I kick arse for the lord
Sean.S
PostPosted: 01:22 - 07 Feb 2016    Post subject: Reply with quote
bikes dont usually get the same milage of a car the same age, i went to view a few 90s sports bikes last year and they all had under 20k. i wouldnt see it as suspicious
sean
Az
PostPosted: 13:27 - 07 Feb 2016    Post subject: Reply with quote
BenCooke wrote:
Hi,
https://www.gov.uk/check-mot-history - go on this site, enter reg' and check the mileage matches the bike. It's probably legit, the last two bikes I bought have been 2003 models and both had under 10k on.
Cheers.
Ben.
-Collector box tends to rust and leaves a nice hole.
-Suspension and brakes aren't great from standard, so if they haven't been looked after they'll be terrible by now.
-The finish isn't good, check for rust and if you do buy it treat it with ACF50.
-Then check the usual; tyres, headstock bearings, wheel bearings, meat on pads, discs not warped, fork seals aren't leaking, chain and sprockets not too worn etc etc
talkToTheHat
PostPosted: 11:03 - 14 Feb 2016    Post subject: Reply with quote
MOT History and HPI. Digital clocks are hard to tamper, but can be swapped, but there would be a DVLA or MOT record of a higher mileage if MOT'd or sold with more miles on it than it has now.
My 2002 bandit had 7600 miles on it when i bought it in december. Appears to have consistently done a a few hundred miles a year for the past few years. Has 9k on it now. Laughing
Bought by noobs as a first bike after DAS or as a workhorse commuter.
Bandit. does. everything.
bamt
PostPosted: 11:13 - 14 Feb 2016    Post subject: Reply with quote
If anything, digital odometers in general are easier to clock than mechanical ones (search for odometer correction - obviously you'd only do this if you have changed the speedo so need to "correct" the replacement). If you have the kit for your bike/car, you could even roll it back every year before MOT time just by plugging in the tool and pressing a couple of buttons so that the MOT record shows a consistent rate of use.
I'd not particularly disbelieve 13K on that bike though, dependent upon condition.
The last post was made 10 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.8 - MySQL Queries: 13 - Page Size: 63.98 Kb
