triumph street triple R as a everyday bike?
Jonny491
PostPosted: 18:56 - 05 Jan 2016    Post subject: triumph street triple R as a everyday bike? Reply with quote
I'm in need of a little advice my A2 test is in February and I'm debating what to.
I've been looking at getting a triumph street triple R however I would be using it everyday as I don't have a car so I'm wondering what's it like as an everday bike?
Or my other plan is the get a bike like a yamaha xj6n which is nearly half the price of a STR and get a car aswell?
Any help or advice would be appreciated
Honda cbr 125 2006- Sold, Current 2012 yamaha XJ6N
robertw95
PostPosted: 19:16 - 05 Jan 2016    Post subject: Reply with quote
As far as im aware you cant get a street triple on an a2 license.
07 Dt125r, sv650s k8, zx6rr 04
Jonny491
PostPosted: 19:19 - 05 Jan 2016    Post subject: Reply with quote
I thought that aswell at it produces 105bhp but the guys at triumph were telling me you can
DRZ4Hunned
PostPosted: 19:22 - 05 Jan 2016    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?p=4111533
DRZ400-SM
FZS600
robertw95
PostPosted: 19:28 - 05 Jan 2016    Post subject: Reply with quote
It can't produce no more than 94bhp end of story, I know about this 'special' model that exists on paper but thats about it
PostPosted: 19:29 - 05 Jan 2016    Post subject: Reply with quote
Triumph engineers, or a dealer trying to sell you a bike?
I'd go with the cheap XJ6 / ER6 or similar, ride it for 2 years restricted or "restricted", enjoy it for what it is, do your full A tests on it by "derestricting" it in the test centre car park and then splooge your load on a Striple R if you still want one.
NJD
PostPosted: 19:33 - 05 Jan 2016    Post subject: Reply with quote
Well this says you can. "Triumph Street Triple 675 (Restricted) A2." ?
someotherguy
PostPosted: 19:39 - 05 Jan 2016    Post subject: Reply with quote
Interested in this thread, not for the "is it A2 legal" aspect, but for the "is it a good everyday bike" aspect.
Awaits Paddy.
Musketeer
PostPosted: 19:41 - 05 Jan 2016    Post subject: Reply with quote
It says you can do your A2 test on one of those.. it doesn't say you can ride it once you pass the test Wink
Pigeon
PostPosted: 20:03 - 05 Jan 2016    Post subject: Reply with quote
Short answer, yes absolutely.
Longer answer, possibly depends what you use your everyday bike for.
If doing 100 mile commute on mway, then you'd probably want a fairing. And probably want a car for winter.
But generally:
+ 74mph in 1st.
+ Narrow bike, good for filtering.
+ Can pull along in 4th at 10mph, so it doesn't bitch / whine so much about which gear you are in (but of course mechanical sympathy applies).
+ 55mpg (2013+ model).
+ Lovely noise, engaging ride, arrive with a smile Smile
+ Servicing fairly straight forward.
+ 130 mile to the fuel light, another 30 in "reserve".
+ Excellent headlights (bug-eye version).
+ VERY comfortable riding position.
+ Daytona chassis innit.
- Very limited storage, under the seat you may get a packet of fags.
- Topbox (considered a sin by most, but I need my portable man cave) brackets are limited, expensive and mine broke after carrying a meagre 15kg at 90mph over many bumps). Chose to make some mild steel supports to solve the issue.
- No fairing for wind / rain protection. To be honest, this does not really bother me, fly screen does a surprisingly good job. I did try a taller screen but found in some cases it was worse and it looked fugly.
EDIT: seems I missed the key point, bike needs to be restricted, apologies Embarassed
PostPosted: 20:04 - 05 Jan 2016    Post subject: Reply with quote
They claim to have one and have a map for one... I've not flashed the map yet because who wants less power.
chickenstrip
PostPosted: 20:32 - 05 Jan 2016    Post subject: Reply with quote
Pigeon wrote:
But generally:
+ 74mph in 1st.
No wonder your feckin valve clearances were so far out Laughing
PostPosted: 21:02 - 05 Jan 2016    Post subject: Reply with quote
That list doesn't magically change the underlying legislation which says:
"A2 motorcycle" means a motor bicycle of a power not exceeding 35 kilowatts, with a power to weight ratio not exceeding 0.2 kilowatts per kilogram and not being derived from a vehicle of more than double its power;
So sure, if you can find one of the apocryphal 70kW stock versions that were apparently made but not registered as a separate model, then you can restrict it down to 35kW.
While you're about it, you could consider riding Willow from Buffy...
https://i.imgur.com/miEIuPi.png?1
... but track down The Wrong Willow from the unaired pilot episode...
https://i.imgur.com/I4xHgyY.jpg
... and then make her wear a Susan Boyle mask.
https://conteudo.imasters.com.br/12994/susan-boyle-mask.jpg
Jonny491
PostPosted: 23:53 - 05 Jan 2016    Post subject: Reply with quote
Thanks for all the help guys I'm going to have a look into whether they can be A2 legal. Ive managed to find a restrictor kit- https://www.phillipmccallen.com/triumph/triumph-street-triple-restrictor-kit-35kw.html
if I cant get one does any know if Suzuki GSR 600 are any good. Ones come up for sale near and its also A2 legal and its only a third of the price of STR. once again any advice would be great, cheers.
PostPosted: 00:19 - 06 Jan 2016    Post subject: Reply with quote
No they cannot be made A2 legal unless they're the rocking-horse-poo 70kW version. I'd be astonished if you ever find one, although I'm sure someone wanting to sell you one will be happy to assure you that it's the magical variant.
GSR600 is fine. Fazer 600 is probably fine. Get something cheap for your first bike, and don't fret about it too much - you'll be itching to change it soon enough anyway.
PostPosted: 00:36 - 06 Jan 2016    Post subject: Reply with quote
I'll map mine to the 75hp one.
Matt B
PostPosted: 11:20 - 06 Jan 2016    Post subject: Reply with quote
The GSR600 is OK as a first bike. Easy to ride but very dull. Suspension is budget and bad budget at that, way too soft on the front end. They are cheap for a reason and not easy to get rid of.
There are far better 600s out there that can be restricted for A2 - Bandit 650S, ER6f, CBF600, and more. They can be found cheap and would make decent first bikes for commuting because they come with a fairing for some protection.
PostPosted: 13:50 - 06 Jan 2016    Post subject: Reply with quote
I can't think of anything more horrible than a restricted stripple. The best part about that bike is the engine.
I would be worried that you will spend a fortune on an expensive bike and hate it. Get something like an ER6 for your restricted time and a stripple after. Thumbs Up
andys675
PostPosted: 01:15 - 07 Jan 2016    Post subject: Reply with quote
afaik, if you want an A2 street triple you have to special order a new one through your dealer that is an export spec 95hp meant for somewhere like spain, they have a softer cam / cams so make low enough power to meet the A2 requirements on restricting
then restrict it
The last post was made 10 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.76 - MySQL Queries: 16 - Page Size: 109.41 Kb
