What License?
S99
PostPosted: 18:55 - 06 Jan 2016    Post subject: What License? Reply with quote
Hello,
I have a question regarding what license I have (Sounds stupid I know) but, I have my CBT and last year I rode a 50cc (at 16). Now, I'm 17 and am looking for a 125cc bike (Note: I still only have my CBT).
I was looking for insurance quotes for a bike I've found and it asks for my type of license and I am not sure weather it is a 'Provisional Moped' or 'Provisional Bike' license. I have searched on other sites and can find no information which would indicate which license I have so I've turned to the forums for advice. Remember I currently only have my CBT.
Another question I have is, Since I'm 17 - What would be the cheapest and most efficient way of doing my bike test?
Thanks.
PostPosted: 21:21 - 06 Jan 2016    Post subject: Reply with quote
You now have provisional A1. The CBT doesn't give you any new category, it just validates any provisional A entitlement (AM, A1, A2, A) that you have due to your age.
But if the insurer doesn't distinguish between various sub-A provisional categories (and they won't) then "provisional bike / motorcycle" is the closest to the truth.
Sadly, the rules changed in 2013. Your only option at 17 (or 18) is to get an A1 license to ride the same 125 that you can ride on your provisionaL entitlement. You don't get any better option until you hit 19.
Most people won't bother doing A1 but (inB4 Tef) it's not a totally worthless license. You can lose the L plates, take a pillion and use motorways. It saves you having to do another CBT, and if you don't already have a car license it starts the clock ticking on your 2 year "new driver" period.
Best news is that you can do A1 on your own 125. You need to book motorcycle theory and then module 1 and module 2 tests yourself. There's nothing complicated in any of them and you can self-teach yourself anything you'll need to know using free online resources.
Really up to you.
M.C
PostPosted: 22:23 - 06 Jan 2016    Post subject: Reply with quote
Feel sad youngsters are restricted to 125's, what was wrong with the old system Sad
I agree with Rogerborg that it's better to do your tests than re-do your CBT, Mod 1's cheap enough (£15) and gives you experience if you go for your big bike licenses later on. Mod 2 costs more (£75-88) but in total with your theory test (£23) comes in around the price of a CBT course.
Only other thing to consider is that I believe (from threads on here) that if you go for your A2 license at 19 and you haven't held an A1 license for 2 years, you still need a valid CBT, theory pass etc. So in other words if you turn 19 and are chomping at the bit to get your A2 license, you might end up having to do your CBT again anyway.
S99
PostPosted: 22:30 - 06 Jan 2016    Post subject: Reply with quote
Really up to you.
So would you suggest that when this (current CBT) expires to just do my CBT again due to the restricted benefits, I also presume completing another CBT would be cheaper?
I've got to be honest, the whole A1, A2 categories confuses me (in terms of tests etc) - I read a topic on this forum (https://www.bikechatforums.com/viewtopic.php?t=33113) but it says the section on full licenses is out of date due to the 2013 update which you mentioned. Is there any thread which clearly explains the new (2013) system?
So, If I don't do my A1 license this year (at 17) but instead do my CBT again towards the end of the year I can go straight on to do my A2 when I am 19? As mentioned above - I'm confused haha.
Thank you both for your help though.
M.C
PostPosted: 23:34 - 06 Jan 2016    Post subject: Reply with quote
We're all confused by the stupid rules Very Happy
Basically the idea behind the rules is that if you have experience you progress quicker. So for example you can go for your A license at 21 if you've had your A2 for 2 years, otherwise the minimum age's 24 (for direct access).
For some stupid reason (I believe) the same applies for A1 > A2. So if you go for your A2 license 18 months after getting your A1 license, because it's not seen as progression (or whatever term they use) the rules regarding having a valid CBT etc. still apply. 2 years or over you don't need a valid CBT.
In reality it's probably not worth worrying about or not taking your A1 tests over, worse case scenario you'll have to do your CBT when doing your A2 license, which sometimes training schools throw in for free (or at a discount) as part of the deal.
It's just one of the stupid quirks of the current system, like how if your theory test expires with you completing your Mod 1 but not Mod 2 you lose your Mod 1 pass Confused
PostPosted: 09:03 - 07 Jan 2016    Post subject: Reply with quote
Sort of. There's no "progressive" access from A1 to A2, but (depending who you ask) getting any A subcategory licence permanently validates provisional entitlement for any A category, so the whole process is:
At 17 or 18, you can do A1. You need a theory pass within the previous 2 years, and a CBT done within the previous 2 years.
At 19 to 23, you can do A2. You need a theory pass within the previous 2 years even if you have A1. You either need a CBT done within the previous 2 years, or to have A1 (or technically AM).
At 24, or at least two years after passing A2, you can do A. You either need a theory pass within 2 years, or to have passed A2 at least 2 years previously (I know that doesn't make sense). You either need a CBT done within the previous 2 years, or to have any other A subcategory license (AM, A1, A2).
It's not designed to be simple, it's a Frankensystem dreamed up by Brussels and gold plated in Whitehall. But none of the actual tests are particularly hard and it is worth it at the end.
Costs are as M.C said. Getting an A1 license on your own 125 costs about the same as re-doing your CBT. If you have the time available, I'd go for the license.
The benefit is that the following A2 and A tests when you get to them are exactly the same. The difference is that you'll do them on a bigger, more capable bike, so they'll actually be easier.
Again, that makes no sense, but welcome to bike licensing.
arry
PostPosted: 09:21 - 07 Jan 2016    Post subject: Reply with quote
And getting the countdown vying on new driver act 2 years is a good shout.
M.C
PostPosted: 19:32 - 07 Jan 2016    Post subject: Reply with quote
https://www.gov.uk/ride-motorcycle-moped/bike-categories-ages-and-licence-requirements
A2:
- Direct access route - theory and practical
- Progressive access route - 2 years experience on A1 motorbike and a further practical test
They seem to think so, and I believe someone on here had this confirmed. They missed out CBT as a requirement (for direct access) but it's listed under the A category, is that an oversight? Confused
I believe if you've held either your A1 license or A2 for under 2 years, you need a valid CBT and theory test pass to move up to the next category.
However I don't recall having to produce my CBT certificate when going for my tests, so you might only have to re-do the theory, as you have to enter the theory test number when booking your practical tests.
PostPosted: 21:37 - 07 Jan 2016    Post subject: Reply with quote
Cheerfully corrected[*]. The 3DLD itself only provides for progressive access from A2 to A, but you're right, we've invented an A1 to A2 progression.
As with A2 to A, the only thing it allows skipping is the theory test, since we require full practical tests to get A2 or A.
https://www.legislation.gov.uk/uksi/2012/977/schedule/3/made
The Man wrote:
(1A) A person is exempt from the requirement to pass a theory test for the purpose of obtaining a licence authorising the driving of a motor vehicle of a class included in sub-category A2 if that person—
(b) has, for a period of not less than two years, held a full licence which authorises the driving of A1 motorcycles
And the same for A2 to A.
[*] Of course, there's no actual requirement to have any "experience" on a motorcycle after your previous test pass.
The last post was made 10 years, 294 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 68.03 Kb
