Gopro sticky mounts
matlow
PostPosted: 16:36 - 08 Jan 2016    Post subject: Gopro sticky mounts Reply with quote
Whats the best least destructive way of removing gopro sticky mounts?
Hornet 600, CBR600F, 929 blade, 07 R1, R1200GS, 09 Blade, 750 SRAD, ZZR1200, 954 Blade, KTM 990 Adventure, Ducati 749s
ScaredyCat
PostPosted: 16:52 - 08 Jan 2016    Post subject: Reply with quote
Least destructive to the object it's attached to or to the sticky mount?
Use a hair dryer to heat up the sticky bit and it'll peal off.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
matlow
PostPosted: 17:00 - 08 Jan 2016    Post subject: Reply with quote
least destructive to the attached object, the mounts are cheap as chips. i thought of hair dryer but alas i'm bald.....
Dave_R
PostPosted: 17:25 - 08 Jan 2016    Post subject: Reply with quote
Use a length of strong dental floss to saw your way though the adhesive pad. Heat will make it a bit easier but floss alone should do the trick.
Use your thumb to rub off the remaining chunks of the sticky stuff, finally use some methylated spirit or isopropyl alcohol to wipe away any adhesive residue.
Doovy
PostPosted: 17:43 - 08 Jan 2016    Post subject: Reply with quote
Expect a blister.
waffles
PostPosted: 17:44 - 08 Jan 2016    Post subject: Reply with quote
Can you borrow a hairdryer from someone? It really is the easiest way to get the mount off with the sticky pad in one go.
Dave_R
PostPosted: 18:24 - 08 Jan 2016    Post subject: Reply with quote
Doovy wrote:
Expect a blister.
How did you figure that? Do you get blisters when you rub off sticky stuff off your helmet? I don't, and I've rubbed my sticky helmet loads.
Oh, unless you're getting blisters after heating the mount with a hot air gun, then I suggest letting it cool a bit before handling Wink
The chunks of adhesive pad clump up when it's rubbed making it easy to remove, the more it clumps, the easier it gets. Scraping the stuff off will take forever and gloves are no good because you'll end up mounting a glove to your helmet. Bare skin is the way to go.
Another method of removing camera mounts, completely without any effort at all, involves leaving your helmet inside a top-box in direct sunlight for a day, twice I've managed this...
PostPosted: 20:05 - 08 Jan 2016    Post subject: Reply with quote
WD40 is great for getting rid of the remaining residue. No need to finger your helmet then. Thumbs Up
PostPosted: 20:34 - 08 Jan 2016    Post subject: Reply with quote
https://www.youtube.com/watch?v=Z1bOM8IJOfI&ab_channel=Techmoan Thumbs Up
Mmm, Isopropanol. Drooling
The last post was made 10 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 62.34 Kb
