Quick boot sole repair
notbike
PostPosted: 01:42 - 13 Jan 2016    Post subject: Quick boot sole repair Reply with quote
The rubber sole on my right boot (tractech evo waterproof) has come away from the rest of the boot at the heel end.
What's a quick way to re-attach it? Don't fancy dishing out for new boot when it's something this minor.
Was thinking some kind of strong glue or that rubber sealant stuff that you can use in bathrooms to fix sinks. Preferably something cheap that will take maximum a few hours to dry as I'll need to fix it before work tomorrow.
Pls share wisdom bcf thx.
SQL
PostPosted: 01:46 - 13 Jan 2016    Post subject: Reply with quote
araldite
notbike
PostPosted: 01:51 - 13 Jan 2016    Post subject: Reply with quote
Ahh nice one man thanks.
Albigularis
PostPosted: 06:52 - 13 Jan 2016    Post subject: Reply with quote
Araldite will set too hard, it'll just break again. I'd use sealant myself.
Is it at the top of the heel plastic where it meets the leather? If so, mine have done the same thing. Every time I go through standing water then slow down, I get a nice puddle of water moving through my right boot.
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
bugeye_bob
PostPosted: 07:09 - 13 Jan 2016    Post subject: Reply with quote
Shoe goo, worked on a few pairs of work boots.
GTR1400
PostPosted: 08:17 - 13 Jan 2016    Post subject: Reply with quote
Same situation as OP, used Gorilla Super Glue Gel. Worked a treat.
Current ride: Honda VFR 800 (Pre-VTEC) Previous: Honda CBF600, Kawasaki ER5, Derbi Senda 125
JonE
PostPosted: 08:25 - 13 Jan 2016    Post subject: Reply with quote
I've always used a contact/impact adhesive for that sort of repair as it stays flexible something like this https://www.amazon.co.uk/Evo-Stik-Purpose-Impact-Adhesive-Super/dp/B002NPTNIK/ref=sr_1_11?s=diy&ie=UTF8&qid=1452669759&sr=1-11&keywords=contact+adhesive should do the trick.
Jon
c_dug
PostPosted: 08:27 - 13 Jan 2016    Post subject: Reply with quote
JonE wrote:
I've always used a contact/impact adhesive.... stays flexible
This.
I've repaired lots and lots of shoes with contact adhesive, we tend to use thixofix, but it's all more or less the same stuff.
PostPosted: 09:01 - 13 Jan 2016    Post subject: Reply with quote
Yup, that's what it's for. It can also re-waterproof the edges of boots that are starting to lift from the sole.
Snowdonia Rider
PostPosted: 09:43 - 13 Jan 2016    Post subject: Reply with quote
My wifes gravy should stick it back together...
https://youtu.be/YexMCgPbh6k
SQL
PostPosted: 23:13 - 13 Jan 2016    Post subject: Reply with quote
Ive always used araldite its still holding my sidis together
PostPosted: 23:20 - 13 Jan 2016    Post subject: Reply with quote
I recently did my army combat boot sole with original gorilla glue.
It's polyurethane foam so has a slightly flexy/spongy feel when cured.
Be aware it expands a bit as it cures and can squeeze out round the edges or force the pieces apart so they need holding together 'till it's set (I clamped mine lightly in the vice for a couple of hours). You can then easily cut off the excess with a sharp knife.
Gorilla glue is my new favourite glue for sticking most things to most other things.
PostPosted: 00:11 - 14 Jan 2016    Post subject: Reply with quote
Jon
Yep I just used that same stuff this week to join a leather drive belt. Ran it for an hour under load with that top pulley at 3000rpm with no sign of it parting.
talkToTheHat
PostPosted: 05:47 - 14 Jan 2016    Post subject: Reply with quote
Contact adhesive if you can get it to work.
I have some 'hybrid glue' gap filling water and heat proof stuff that does for quick shoe repairs, sticking heated grips on and other such tasks where one part needs to slide a bit before sticking. Grey tube, blue cap. Pricey but works quite well for generic bodges,
Bandit. does. everything.
PostPosted: 07:49 - 14 Jan 2016    Post subject: Reply with quote
The trick to contact adhesive is to clamp it up tight for 24hrs. Sure it 'grips' instantly but that doesn't mean all the solvent has dissipated. glue the boot and hold the two parts together tight for a day and it'll be a good joint.
The last post was made 10 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 87.26 Kb
