 ..... Quote Me Happy
| WD Forte |
 WD Forte World Chat Champion
| Ste |
 Ste Not Work Safe
 Posted: 17:34 - 10 Jan 2016 Post subject: |
Using a pressure washer to unblock drains? Do it!!!  |
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 18:07 - 10 Jan 2016 Post subject: |
Yeah I tried something along those lines, I think it was called a drain auger, but the coil wasn't stiff enough to be of any use. I've tried attacking it from the other end but as far as I can tell there's a hefty bend to negotiate - the rods are too stiff and the auger thing too flimsy to get round. |
| CaNsA |
 CaNsA Super Spammer
| skiptalker |
 skiptalker Borekit Bruiser
| CaNsA |
 CaNsA Super Spammer
| stinkwheel |
| mudcow007 |
 mudcow007 World Chat Champion
| stinkwheel |
| mentalboy |
 mentalboy World Chat Champion
 Posted: 17:57 - 14 Jan 2016 Post subject: |
I've had success in the past just using a length of hose pipe, hook it up to a water supply, turn on and then just keep feeding it around the u-bend. If it doesn't like the bend (or the muck it's trying to push into) don a pair of long gloves - as you went chemical before mechanical - and get your arm in as far as possible to aid pushing the hose through.
Still wet and messy but does avoid the inevitable blow back when using a pressure washer.
Top tip if you use this method: Cut off the last few feet of the hose after use and bin it as you won't want to be cleaning it  |
| doggone |
 doggone World Chat Champion
| Suntan Sid |
 Posted: 19:05 - 14 Jan 2016 Post subject: |
| Joe wrote: | On further inspection the cover appears to be metal and has two screws in opposite corners. I know for a fact they haven't been removed in over 8 years so it's going to be a bit of a battle. |
For a couple of years I worked with a CCTV unit, mapping sewer systems, IME brute force is, invariably, the way to go.
If you get the screws out and the cover still won't budge, try and break off one corner of the cover, if you manage that, without completely destroying the whole thing, use the hole you've made to lever it out!
If you wanted to be neat and tidy you could drill a few holes across one corner, should make it easier to break a bit off!
| CaNsA wrote: | use a rubber mallet around the edge of it to loosen it up, then mtfu. |
Ok, probably bigger covers than the one Joe's talking about, but we used to us, bleedin', big sledge hammers to loosen stuck manhole covers, we never broke one! ____________________ "Everybody needs money, that's why they call it money!"  |
| CaNsA |
 CaNsA Super Spammer
| almostthere |
 almostthere Traffic Copper
 Posted: 22:12 - 15 Jan 2016 Post subject: drains |
Karcher drain cleaning attachment is the dogs sorts out most blockages in no time, Be careful using it inside on pushfit waste fittings it can blow the joints apart  ____________________ Beer, It's the reason I get up every afternoon
www.mfairco.uk |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 22:28 - 15 Jan 2016 Post subject: |
Drape a towel over the sink's overflow and plughole, same goes for the washing machine waste pipe.
If you decide to break the cover a piece of *12mm ply painted in non slip does a good bodge.
*Give or take a bit.
Good luck.
 ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| Suntan Sid |
 Posted: 22:41 - 15 Jan 2016 Post subject: |
| CaNsA wrote: | How much did you weigh them in for? |
Unfortunately my employer, the water authority, didn't look too kindly on such behaviour!
You'd be surprised how much of a beating a M/H cover can take.
We had loads of sales reps round, trying to flog us special machines for dislodging, recalcitrant, manhole covers, we manged to destroy two or three!
AFAIK bouncing the cover with a, fcuk off, sledgie is still the best method, although probably now outlawed by 'elf' 'n saftee, for no good reason! ____________________ "Everybody needs money, that's why they call it money!"  |
| Skudd |
 Skudd Super Spammer
| hellkat |
 hellkat Super Spammer
The last post was made 10 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
