Anyone good with excel. (linking cells)
TheSmiler
PostPosted: 11:13 - 17 Jan 2016    Post subject: Anyone good with excel. (linking cells) Reply with quote
I'm sorting out an expenditure sheet in excel, I've used the developer tools for check boxes. Now what I'm trying to do is to work out how much I've got to spend depending if an item has been ticked.
An example of what I'm trying to do below. So the total left column at the moment is only a sum function which is selected. But I don't really want to do this every time I click an item off.
https://i.imgur.com/wDAwWgs.jpg
Can anyone help Question
James83
PostPosted: 12:04 - 17 Jan 2016    Post subject: Reply with quote
This is technically possible, but if the list is going to be remotely long, it'll be a pain to add the check boxes. You may well be better off with a simple 'Y' or 'N' written into the cell instead.
If you are committed to using the checkboxes, you first need to get the state out of it. Select a checkbox by ctrl-clicking it, then in the formula bar, put an = sign and then click the cell you want the value to go into. That cell will then show either TRUE or FALSE depending on if the box is ticked or not. What you could do is assign the checkbox values to the cell they are sitting over the top of in column D. If you set the font to white, you won't see them.
You then need to do a sumif to get the total, something like:
=sumif(D:D,TRUE,C:C)
Jonathan A wrote: tart.
J.M.
PostPosted: 13:30 - 17 Jan 2016    Post subject: Reply with quote
I assume you only want 1 answer for total cost and total left. Or do you want a breakdown of what total left and total cost was after each purchase?
One Total
Uses Y/N instead of checkbox. 500 is arbitrary starting budget.
Total Cost: =SUMIF(DVery Happy,"=Y",C:C)
Total Left: =500-G2
Total After Each
Again uses Y/N. 500 is arbitrary starting budget. 120 is arbitrary total cost before starting spread sheet.
Initial total left: 500-SUMIF(D2,"=Y",C2)
Initial total cost: =120+SUMIF(D2,"=Y",C2)
Next total left: =F2-SUMIF(D3,"=Y",C3)
Next total cost: =G2+SUMIF(D3,"=Y",C3)
Then;
Every time you want to add a new item, or a bunch of them, select column F&G for the final row. There will be a blue square in the bottom-right of the bottom-right most selected sell. Drag it down to the next row.
Attachment may/may not work as I don't have office installed to test it.
2004 R1 & 2018 XSR900
TheSmiler
PostPosted: 14:28 - 17 Jan 2016    Post subject: Reply with quote
Changed it to the yes no statement and added an extra tab which is now coloured differently and locked. Worked out in the end. Now if I change a sum or change one to an Y then it all sorts itself out thank you.
The last post was made 10 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 41.35 Kb
