My Honda 175 bike's missing alot
Usman
PostPosted: 14:54 - 13 Feb 2005    Post subject: My Honda 175 bike's missing alot Reply with quote
The whole thing started when i started the engine first time in the morning,i guess the wrong thing i did was i really accelerated the engine before riding to allow the engine to get hot quickly so it had no hickups...well,well now it's night over here & i had to go collect almost 100 $ from a guy & cant even think of it cause the bike's missing really hard,I cleaned the plugs,looked at the gap,cleaned a bit of oil on the side point,It ran quite good for 10 min after that again the same problem...I just got the clutch plates changed day before yesterday,
Any suggestions guys also on side point cleaning & setting
Honda cd175
Scotsman37
PostPosted: 18:11 - 13 Feb 2005    Post subject: Reply with quote
Maybe the carbs need to be removed to give the jets and that a good clean, but prior to that you could use something like Redex to give the fuel system a clean to see if that helps it.
Possibly your float needle is sticking within the float chamber.
Have you given the air filter a clean lately?
Have you tried replacing the spark plug with a new one just in case it's a developed a fault.
BFG
PostPosted: 10:54 - 14 Feb 2005    Post subject: Re: My Honda 175 bike's missing alot Reply with quote
I would agree. This is a really bad thing to do to an engine. Can you elaborate? If you revved it really hard for a long time (say a minute) when it was cold you might have done some hard damage.
Oil on the plugs could be a bad sign. After you clean the plugs, how long before it oils up again?
How badly is it missing? Does it miss in all throttle openings? At all revs? This info would be useful.
The last post was made 21 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 35.25 Kb
