If Oxford chains are the poor baby, which is the daddy?
Kaya75
PostPosted: 12:24 - 23 Jan 2016    Post subject: If Oxford chains are the poor baby, which is the daddy? Reply with quote
Questions in the title to be fair..
Which chain and lock is the hardest, which chain is the one that make scumbag thieves look for something easier?
Pass the popcorn Thumbs Up
ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2.
someotherguy
PostPosted: 12:31 - 23 Jan 2016    Post subject: Reply with quote
https://i.imgur.com/Bs17yJ2.jpg
-Matt-
PostPosted: 12:33 - 23 Jan 2016    Post subject: Reply with quote
Almax and Pragmasis tend to be regarded as better ones.
Can still both easily be cut with the right tools in a couple of minutes though.
NJD
PostPosted: 12:46 - 23 Jan 2016    Post subject: Reply with quote
A thief isn't going to look at a bike that they want to steal and have a frank Spencer moment of "oh Betty, I don't know what to do" while their knee's quiver, they're clearly going to come prepared to destroy any attempts you've made to secure your bike. ie; bolt croppers for the chain etc. So in regards to the latter part of your question, nothing IMO, if a thief wants it they're going to do all they can to take it.
In regards to chains Almax/Pragmasis will give you a better chance of keeping your bike as opposed to Oxford or any of the shelf re-branded small chain link sized chain.
Pragmasis don't even recommend that you use their 11mm chains for motorbikes, if you compare that to the 9.5mm chain links that oxford sells with their "heavy duty" chain you should be asking yourself serious questions about how secure your motorbike is secured with a chain that has links smaller than what's recommended for a bicycle.
13mm or 16mm as a carry chain and 19mm for home is the general recommendation.
Kaya75
PostPosted: 13:01 - 23 Jan 2016    Post subject: Reply with quote
"now which end did I lock the bike to? " lol!
Kaya75
PostPosted: 13:03 - 23 Jan 2016    Post subject: Reply with quote
Thanks NJ, I'll take a look at those 19mm Thumbs Up i knows if they want they'll have it school of thought, I just want to narrow down the " they" as it where... Thumbs Up
andyscooter
PostPosted: 13:10 - 23 Jan 2016    Post subject: Reply with quote
Think I may struggle to get that through my 10 inch wheels
NJD
PostPosted: 13:22 - 23 Jan 2016    Post subject: Reply with quote
Is budget an issue?
Are you looking for home security, a carry around chain or both?
19mm and ground anchor for home. 16mm as a carry chain.
If budget is an issue you could turn that 19mm into a 16mm and just have a two in one to carry around and for at home.
Pragmasis 16mm / untouchable lock if you want a cheaper 16mm chain. Pragmasis 13mm as a carry chain if you're on a budget.
You'll want to consider:
a) Your luggage options, tailbag or topbox is recommended for transporting chains.
b) Point of which you're looping the chain through the bike, is there a gap big enough to get a 19mm or 16mm through?
c) Length to ground anchor or mounting point when out and about?
PostPosted: 13:26 - 23 Jan 2016    Post subject: Reply with quote
eBay ads at the bottom of the page have a specific tool for breaking Oxford chains. Wink
-Matt-
PostPosted: 13:30 - 23 Jan 2016    Post subject: Reply with quote
If budget/weight is an issue - i'd consider if the 19mm (Series IV Almax) are going to be that much more use than the 16mm (Series III Almax).
If I remember correctly, when I contacted them a few years back the main difference between the two was the 19mm chains were supposed to survive ''upto 4 minutes'' against power tools etc and the 16mm chains survived ''around 2 minutes''.
Realistically if someones bothered to take power tools along to deal with the chain in the first place an extra minute or two is unlikely to make much difference in stopping the bike getting taken, and you're going to be paying quite a lot more, for an even heavier chain. My 1.5m 16mm is hard enough to transport as it, I wouldn't like to attempt it with a 19mm really.
PostPosted: 13:37 - 23 Jan 2016    Post subject: Reply with quote
19mm vs 16mm, the more chance there is of a bike thief not paying close attention to your bike and going to find something easier to steal? The fact they can both be cut with the same tools is besides the point if the 19mm looks badass enough to scare thieves away. Razz
PostPosted: 13:59 - 23 Jan 2016    Post subject: Reply with quote
Like for like a 19mm chain will take more than 40% extra shear force to cut than a 16. They are much stronger for the extra 3mm.
Skudd
PostPosted: 14:05 - 23 Jan 2016    Post subject: Reply with quote
My Abus lock and chain has survived a few bike thefts, the bikes didn't, but the chain did. The bikes were write offs due to the theft attempts but the chain is still going strong 20 odd years later.
PostPosted: 11:26 - 24 Jan 2016    Post subject: Reply with quote
Butter knife?
Val
PostPosted: 12:05 - 24 Jan 2016    Post subject: Reply with quote
It depends on the bike. If it is expensive no chain can protect it. You need layred protection. Chain for the opportunistic scumbacks. Alarm and better closed space.
19mm chain will take few seconds with proper equipment:
https://vimeo.com/59633136
ADSrox0r
PostPosted: 12:18 - 24 Jan 2016    Post subject: Reply with quote
Val wrote:
proper equipment:
Christ, if they turn up with that thing they can bloody well have it cos I sure as hell ain't going to be seeing it in this country again. That's professional stealing-to-order territory.
Kaya75
PostPosted: 15:01 - 24 Jan 2016    Post subject: Reply with quote
Thanks all Very Happy , my ground anchor is the tow loop of a two ton van, parked behind two locked galvinised farm gates, it's in a compound at work, bikes a bandit..
So all considered. A quality 19mm chain will do nicely, the chain I'll keep longer then the bike, so want To invest for the future as it where too.
Thx all, I'll update with purchase in a couple of months... Once piggy bank as recovered from Christmas! Thumbs Up
Albigularis
PostPosted: 21:48 - 24 Jan 2016    Post subject: Reply with quote
How does this do when relating to the chains then? The Abus 16mm chain can be cut in seconds, the Almax 16mm breaks croppers. I'd volunteer a link of my Almax to find out if a portable hydraulic cropper could get through it. I'm sure when Almax used to do shows, they claimed at the shows that it couldn't be done...
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
PostPosted: 21:54 - 24 Jan 2016    Post subject: Reply with quote
Rogerborg wrote:
Butter knife?
Oxford Chain Breaker.
Razz
Londoner2015
PostPosted: 16:48 - 17 Feb 2016    Post subject: Re: If Oxford chains are the poor baby, which is the daddy? Reply with quote
As others have pointed out, Almax and Pragmasis are the best.
The general rule is that chains up to 11 mm can be cut with bolt croppers.
13mm chains can theoretically be cut with bolt croppers, but it takes a biig guy using biig croppers.
>= 16mm and bolt croppers are useless.
Of course nothing can resist a thief with a grinder and enough time on his hands.
I prefer Pragmasis because they give more options: in terms of width, length and also because you can buy their 13mm and 11mm chains with a noose: you insert one end of the chain into the other, almost doubling the usable length. They also have an anti-pinch pin which is useful.
All the details are on the websites, but these chains are heavy. The 16mm and 19mm chains are not meant to be carried around - you had better leave them in a fixed spot like your garage. 13mm chains can be carried around more easily. In another forum a guy said he managed to carry a 1.2 metre 13mm Pragmasis chain under the seat of his R1.
If you don't secure your bike to street furniture, then chains do not offer more protection than a ulock; the abus granit extreme 59 plus is one of the best, and is more convenient to carry than these chains.
stevo as b4
PostPosted: 20:13 - 17 Feb 2016    Post subject: Reply with quote
I'm quite liking the look and quietness of those pro electric or cordless chain breakers. They look like nice bits of kit.
I just assumed pro's used small gas torches and cordless power tools, though for a quick but noisy in/out job a Sthil 2smoke with a nice quality wheel would probably be the fastest thing you could use, especially if using a van to take the bike?
Kaya75
PostPosted: 21:00 - 17 Feb 2016    Post subject: Reply with quote
My biggest concern is they take the van and drag the bike though..
Kaya75
PostPosted: 21:04 - 17 Feb 2016    Post subject: Re: If Oxford chains are the poor baby, which is the daddy? Reply with quote
I wasnt considering a Ulock in fairness, thanks good point Thumbs Up
gorillaonabik...
PostPosted: 23:09 - 17 Feb 2016    Post subject: Reply with quote
When I had a drive, I used a gorilla lock. Cemented a foot into my driveway, it was impossible to cut with traditional bolt cutters as it is designed in a weird way.
It's possible to bust through it, it's just that that croppers are the wrong tool and those are the devices thieves typically carry. I miss my driveway and gorilla lock...
https://i.ytimg.com/vi/5_c0-PkbDMw/maxresdefault.jpg
FZR400 (blown engine), ZXR750 (blown engine), ZX6R (accident), CBR600 which had engine issues after which I learned to change gear..., CBR900, CBR924 (stolen), CB600, CB1300 (everything blew up), BMW K1300GT (written off, hit from rear while stationary), Bandit 1250 for a couple of months, Triumph Sprint ST 1050 (nicked) and somewhere in there, I wrote off a Ducati 748 at Cadwell.
Andy_Pagin
PostPosted: 23:58 - 17 Feb 2016    Post subject: Reply with quote
Close, but no cigar
https://i636.photobucket.com/albums/uu84/anadin96/ikbrunel.jpgIt's an indisputable historical fact no-one ever stole Isambard Kingdom Brunel's motorcycle.
The last post was made 10 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 133 Kb
