| P.addy |
 P.addy Red Rocket
 Posted: 20:23 - 26 Jan 2016 Post subject: Car MOT and dash lights... |
Ok so I'm looking at a car currently that has an SRS light on. This is due to a new steering wheel being installed. The car is a 2004 UK car.
Will this be a fail? It also has no cat however I can bodge that in. What I don't want is to have to find a stock wheel and airbag.  |
| techathy |
 techathy Traffic Copper
 Posted: 20:35 - 26 Jan 2016 Post subject: |
Yes, an SRS indicating a fault is an MOT failure.
There is a very good reason that one of the first things I did with my track car is replace the manufactures cluster with a SPA Design item  |
| Nb |
 Nb World Chat Champion
| techathy |
| Nb |
 Posted: 21:51 - 26 Jan 2016 Post subject: |
It will pass if the tester notices it atall.
Reason for rejection:
A Supplementary Restraint System (SRS) malfunction indicator lamp indicating a system malfunction.
There is no fail for the light not coming on.  ____________________ Cbr1100xx blackbird gone, mk4 golf gt tdi chav now
Columbus travel insurance are crap!! Do not use! |
| binge |
 binge Emo Kiddy
With bulb removed it will pass with an advisory.
The other option is to chop the plug to the air bag off (loom side), and bridge it with a 501 bulb (Standard sidelight bulb).
The 5w of resistance tricks the car into thinking the airbag is present and working, so the light cycles for the 4 to 5 seconds during ignition start up, then goes out.
Naughty little trick there for ya. |
| Nb |
 Posted: 21:54 - 26 Jan 2016 Post subject: |
I prefer the maplins 2.7ohm resistor myself binge  ____________________ Cbr1100xx blackbird gone, mk4 golf gt tdi chav now
| techathy |
 Posted: 23:10 - 26 Jan 2016 Post subject: |
So after wading through this it tuns out if Joe public asks the DVLA for a document the outlines what does & doesn't pass an MOT you get a bit of paper which is effectively a load of bollox. |
| Alpineandy |
 Alpineandy World Chat Champion
| bugeye_bob |
 Posted: 23:44 - 26 Jan 2016 Post subject: |
My daughter's car is missing the driver's airbag and it passes every year because the led fell off the dash cluster. ____________________ a.k.a 'Geri'
| Ste |
 Ste Not Work Safe
 Posted: 00:01 - 27 Jan 2016 Post subject: |
| Shaft |
 Shaft World Chat Champion
 Posted: 00:26 - 27 Jan 2016 Post subject: |
If it's been fitted with an aftermarket steering wheel that clearly has no provision for an airbag, does it not fall under RFR 1, "An airbag obviously missing or defective"? ____________________ Things get better with age; I'm close to being magnificent........
| panrider_uk |
 panrider_uk World Chat Champion
| Nb |
| P.addy |
 P.addy Red Rocket
 Posted: 16:09 - 27 Jan 2016 Post subject: |
Cheers guys, its a Civic Type R, EP3 era with a bit of work done and 225hp with a modified EK9 LSD so its had a bit of work but is stupidly low miles and stupidly cheap, owned by a car fanatic who works with a friend. Its not been bodged and shit so would be a nice car to run along side the wagon.
His friend does MOTs so is obviously glancing over it, but its going to be obvious with my own MOT place. I can't drive to his in Dorking every time I want an MOT  |
| Nb |
| P.addy |
 P.addy Red Rocket
| Nb |
| P.addy |
 P.addy Red Rocket
| Nb |
| Taught2BCauti... |
The last post was made 10 years, 265 days ago. Instead of replying here, would creating a new thread be more useful? |
