Home web server logs, advice required
t121anf
PostPosted: 10:03 - 31 Jan 2016    Post subject: Home web server logs, advice required Reply with quote
I bought a raspberry pi to play with and have setup a simple web server on it.
I've been keep an eye on the logs for apache, and noticed entries such as
Code:
185.25.151.159 - - [31/Jan/2016:07:02:24 +0000] "GET http://testp4.pospr.waw.pl/testproxy.php HTTP/1.1" 404 461 "-" "Mozilla/5.0 (Windows NT 5.1; rv:32.0) Gecko/20100101 Firefox/31.0"
Should I be concerned or is this pretty normal?
t121anf
PostPosted: 10:12 - 31 Jan 2016    Post subject: Reply with quote
Did a google search and google suggests it's nothing to worry about as I don't run PHP.
PostPosted: 11:29 - 31 Jan 2016    Post subject: Reply with quote
<-- You'll want PHP, for hijinks.
You're going to see all sorts of WTF? in there. If someone were to tell me that the internet is primarily autonomous now, I wouldn't instantly laugh it off. It's not worth worrying about though, as that's a very deep well.
t121anf
PostPosted: 11:34 - 31 Jan 2016    Post subject: Reply with quote
Php can come in time,
Andy_Pagin
PostPosted: 11:54 - 31 Jan 2016    Post subject: Reply with quote
You'll get blitzed with attempts to hack your server. I used to have a home Linux server with the ssh port open so I could administer it remotely, the security log was crammed with attempts to hack root using commonly used password phrases.
PostPosted: 13:02 - 31 Jan 2016    Post subject: Reply with quote
My logs now go to /dev/null, by the way, it's literally not worth wasting time or space on them.
Oh, if you're running off an SD card, I'd recommend that you set up a small RAM disc for anything that you do allow to get written:
https://www.domoticz.com/wiki/Setting_up_a_RAM_drive_on_Raspberry_Pi
Andy_Pagin
PostPosted: 14:02 - 31 Jan 2016    Post subject: Reply with quote
True, but for a newbie it's a useful wakeup call to what a shitty world we live in.
PostPosted: 14:18 - 31 Jan 2016    Post subject: Reply with quote
Logs are the Daily Mail of info, they give you eye cancer if you expose yourself too much.
t121anf
PostPosted: 19:43 - 31 Jan 2016    Post subject: Reply with quote
Ta will read through it at work, I guess this is to avoid the limited read/write of flash media?
PostPosted: 19:48 - 31 Jan 2016    Post subject: Reply with quote
Yup. There's likely no real need to write anything to the SD, unless you specifically want to retain logs.
chrisw
PostPosted: 14:26 - 02 Feb 2016    Post subject: Reply with quote
Except that you can use them to feed Fail2Ban - a valuable tool if you have internet accessible services.
Binning logs is a bad idea generally, if you don't want to store much then turn logging down and up the rotation.
The last post was made 10 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 70.11 Kb
