| rehmh05 |
 rehmh05 Nova Slayer
| Nobby the Bastard |
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:22 - 31 Jan 2016 Post subject: |
Bit harsh?
Any sound from the starter solenoid? Have you tried shorting the terminals on it with an insulated screwdriver? ____________________ Biking is 1/20th as dangerous as horse riding.
| rehmh05 |
 rehmh05 Nova Slayer
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| rehmh05 |
 rehmh05 Nova Slayer
| RhynoCZ |
 RhynoCZ Super Spammer
| Kawasaki Jimbo |
 Posted: 22:09 - 31 Jan 2016 Post subject: Re: bike won't turn over ..? |
I think my battery question might have been a stupid one but it's too late to delete it!
I was also thinking of the ignition fuse but you say the headlamp responds to the start button by switching off, as expected. Unlikely to be the ignition fuse then, but maybe worth checking it hasn't blown anyway. |
| rehmh05 |
 rehmh05 Nova Slayer
| Kawasaki Jimbo |
| rehmh05 |
 rehmh05 Nova Slayer
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:41 - 01 Feb 2016 Post subject: |
Find your starter motor. There will be a fat cable running from it to a solenoid, something like this:
https://tws.dk-server.co.uk/item104222-5b.jpg
Under that translucent cover you can see two big screw erminals. The wire from your starter motor will go to one of them. The other will go to the battery +ve terminal, possibly via a high amperage fuse.
If you pop that cover off and then put the blade of a screwdriver across both terminals, you'll connect the battery +ve direct to the starter motor. It'll will spark up a treat, and be prepared to pull the screwdriver away hard as it might even spot-weld itself to the terminals.
If the starter spins, it's likely that the solenoid is duff. But try cleaning up the connectors anyway. I'm not sure why there are what appears to be 4 low amperage wires going into it, it should only need two. Possibly the others are from whatever sidestand/gear/clutch magic is designed to stop it spinning up while in gear / without the clutch held in or whatever ritual you need.
If the terminals spark but the starter doesn't spin then either your main -ve earth is hooky or the starter is borked.
If the terminals don't spark then you're not getting +ve to the solenoid - check for a blown fuse between it and the battery, although it's high amperage so there may not be one.
A multimeter will take most of the guesswork out of it. ____________________ Biking is 1/20th as dangerous as horse riding.
| rehmh05 |
 rehmh05 Nova Slayer
| RhynoCZ |
| Rogerborg |
 Rogerborg nimbA
| rehmh05 |
 rehmh05 Nova Slayer
| RhynoCZ |
 Posted: 11:40 - 01 Feb 2016 Post subject: |
The battery is dead, OP. Or there is a short circuit somewhere. Try a new battery, ask a mate to borrow you his.
Voltage is not everything, the Amps matter as well. Amperes is what defines a performance of a battery, Ah its capacity. That is why you would never start an automobile with a small motorcycle battery, even though it's a 12v one as well. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| rehmh05 |
 rehmh05 Nova Slayer
| weasley |
 weasley World Chat Champion
| Pete. |
 Pete. Super Spammer
| rehmh05 |
 rehmh05 Nova Slayer
| rehmh05 |
 rehmh05 Nova Slayer
 Posted: 17:08 - 01 Feb 2016 Post subject: |
https://i66.tinypic.com/2ns6gc8.jpg ____________________ - CBT 31/10/12 - CBR 125 bought 01/11/12
- Theory: 07/11/12 - Mod 1: 19/11/12 - Mod 2: 28/11/12
- 24/08/13 - Bandit 600 |
| Rogerborg |
 Rogerborg nimbA
| RhynoCZ |
 Posted: 18:33 - 01 Feb 2016 Post subject: |
Cool you've found the culprit. I completely forgot there was a clutch kill switch. I do recall my mate's SV1000 needed the clutch lever to be squeezed when starting the engine, even though he was in neutral with the side stand up.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Kawasaki Jimbo |
The last post was made 10 years, 70 days ago. Instead of replying here, would creating a new thread be more useful? |
