leaking front door.
WULFSTAN
PostPosted: 13:39 - 06 Feb 2016    Post subject: leaking front door. Reply with quote
My front door has started leaking between the black seal and the bottom of the door. Ive put a load of grease on top of the seal to try and stop the water is this going to work or is it new seal time? You can see in the pic the water on top of the seal thanks.
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
mudcow007
PostPosted: 13:53 - 06 Feb 2016    Post subject: Reply with quote
isnt the rain suppose to run off the brass strip?
So the rain now is getting past the brass strip an sitting on the seal..
am i thinking about this wrong?
A seal cant cost that much though, even just to check
PostPosted: 16:11 - 06 Feb 2016    Post subject: Reply with quote
Just replace the seal. Pennies worth.
Top tip: Apply either washing up liquid or silicone lube to the bit of the seal that pushes in before you start or it's a total pain in the arse. I've been fitting new seals to all my windows and it makes it WAY easier.
doggone
PostPosted: 18:51 - 06 Feb 2016    Post subject: Reply with quote
You probably knew but the brass-looking channel should have two or more small drain holes which can easily block.
Doesn't sound like that's the issue here though.
Triton Thrasher
PostPosted: 20:54 - 06 Feb 2016    Post subject: Reply with quote
Ok not a medical matter.
Rrrrrrrrrrrrrrrrrr
The last post was made 10 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 43.3 Kb
