Kickstand switch has a mind of its own
joezxr
PostPosted: 14:24 - 08 Feb 2016    Post subject: Kickstand switch has a mind of its own Reply with quote
Iv recently developed an intermittent problem with my 2003 ZX6R!
Every now and again I pull up to park, kick my stand down whilst in neutral and its shut the bike off? I then have to kick my stand up and down a few times to get the starter button to work again...
I have cleaned the switch, opened it up and followed the wiring and everything looks fine, its like its working opposite to how its supposed to.
Just some info, I can start it in gear with the clutch pulled and stand up, and if I go into gear with stand down it cuts out like its supposed to
Anyone know if this is a common thing and how to fix it?
Doovy
PostPosted: 15:16 - 08 Feb 2016    Post subject: Reply with quote
Get a new sidestand switch. They're not usually expensive.
PostPosted: 15:17 - 08 Feb 2016    Post subject: Reply with quote
Shove a bent paperclip into the clutch switch terminal block and remember to put the stand up before you ride away.
pepperami
PostPosted: 17:53 - 08 Feb 2016    Post subject: Reply with quote
This ^ +1 it`s almost what I have done with the side-stand switch on my Hyosung.
I made a small loop with terminals on each end and plugged it onto the connection.
Side-stand switches are prone to the wet and dirt because of where they live.
joezxr
PostPosted: 23:03 - 13 Feb 2016    Post subject: Reply with quote
Thanks for the advice but the problem is not the kickstand switch it turns out because it is working cutting off the bike like it should...
So iv been over the whole starter system with a multimeter!
Kickstand switch operational
Clutch switch operational
Neutral switch is in good condition and works
BUT
I can't seem to figure out how to test the wire going to the neutral switch, both the clutch switch wiring and neutral switch wiring integrate and go into a red and green wire that enters the fuse box through the starter system fuse and starter circuit relay which is located in the fuse box, as far as I'm aware this wire sends a signal the the starter system and ECU telling the bike its okay to start.
If I pull the clutch there is resistance from the fuse box to clutch switch, but I'm not sure how to link the circuit from the nuetral switch because I don't understand what type of electrical black magic it uses.
Does the switch have a constant live going to it and when the switch is pushed it grounds itself to send a signal or visa versa?
binge
Emo Kiddy
PostPosted: 23:07 - 13 Feb 2016    Post subject: Reply with quote
Had a similar problem with my NC29 back in the day.
When I hit about 9k RPM, the vibrations would cause the switch to cut the engine out, but it would be a juddery, jerky ride as it dropped below, and rose above 9k.
Bypassed the piece of shit in the end, and learned to check the stand before pulling away (Like you should do anyway). Smile
Ariel Badger
PostPosted: 00:33 - 14 Feb 2016    Post subject: Reply with quote
Short it out, it was only put there because of H&S Nazis.
iooi
PostPosted: 09:28 - 14 Feb 2016    Post subject: Re: Kickstand switch has a mind of its own Reply with quote
I have cleaned the switch, opened it up and followe the wiring and everything looks fine, its like its working opposite to how its supposed to.
So swith OK then.
That leaves one other option. The bit on the sidestand that engages to the switch is not engaging as it should.
IE. Sidestand pivot joint is worn or a bit is bent or crap is stopping it going fully back.
Just short the switch out Rolling Eyes
There is another option..... User error 650.....
The last post was made 10 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.41 - MySQL Queries: 15 - Page Size: 58.94 Kb
