[Car] Misfire underload?
mudcow007
PostPosted: 08:44 - 09 Feb 2016    Post subject: [Car] Misfire underload? Reply with quote
My dad has a W reg MX5, last week it developed a misfire. No worries i thought it will be a coil, lead etc...
So he bought a coilpack (without testing his old one) an some "go faster" red leads.
I fitted these on the weekend, initially the car sounded fine until he accelerated away/ put it under load - it started misfiring again.
I refitted the factory leads (with the new coils) an the car was working great again underload etc.
He came to use the car yesterday an its back to misfiring.
Ive got his old coils in work with me to test em today but i dont think its coils..
didnt change/ check plugs but they were supposedly changed last year, an the insulator does look shiny white so reckon they were changed.
any thoughts?
Oldie
PostPosted: 08:57 - 09 Feb 2016    Post subject: Reply with quote
You will have to check each plug for a proper spark. Even new plugs can be faulty. A weak spark will cause mis-firing.
bugeye_bob
PostPosted: 09:04 - 09 Feb 2016    Post subject: Reply with quote
as above plugs, age of plugs, ceramic intact and gap ok ?
PostPosted: 10:19 - 09 Feb 2016    Post subject: Reply with quote
Probably plugs / spark, but I had a misfire under high throttle / low revs on my C3 due to a hooky electrical connection on an injector.
UncleFester
PostPosted: 10:28 - 09 Feb 2016    Post subject: Reply with quote
As above, would also check plugs / gaps.
Equally ( assuming it has a diagnostic port) i'd do a scan and see if there is an o2 sensor fault or a blocked / dying cat.
A gentle tap from a rubber hammer will tell you if the Cat innards have become detached.
2017 Z1000SX
bugeye_bob
PostPosted: 11:06 - 09 Feb 2016    Post subject: Reply with quote
a quick Google mentions the CAS is a popular problem.
mudcow007
PostPosted: 12:35 - 09 Feb 2016    Post subject: Reply with quote
Will whack some plugs in it tonight, so how that goes, might even give the MAF a spring clean too. It has a K&N fitted to it (has done for about 3 years)
cheers for the suggestions
mudcow007
PostPosted: 08:32 - 10 Feb 2016    Post subject: Reply with quote
sorted I think
Bunged some new plugs in, all looked ok except for No.1 which had loads of gung above the nut - the electrode looked a bit sooty...
tested the car, still had a misfire
So, replaced the lead to No.1 an the car now runs sweet as a nut - I will get some more new leads for him to replace the rest of them (they look original Shocked )
I reckon a mixture of new leads an plugs sorted it?
The gung looks like (an smells like) something has gotten onto the rocker cover an died an basically melted down onto the plug and onto the HT lead - the smell is/ was horrendous Sick
The last post was made 10 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 54.99 Kb
