Wiring a tachometer (in dash unit) what does it connect to?
oberonspacefr...
PostPosted: 12:11 - 10 Feb 2016    Post subject: Wiring a tachometer (in dash unit) what does it connect to? Reply with quote
ive spent quite a while on youtube now, and i have a general gist, but i thought id check opinions on here.
the tach is part of a new koso type digital dash.
there are no instructions, other than to tell you which wire should act as the feed for the tach.
YOUTUBE says 3 things
1. wrap it around the spark plug cable, and tie it off (wierd)
2. attatch it to the live output of the coil
3. bizzarely, id have thought, attatch it to the negative of the coil.
i must surely be missundertanding no 3 as thats just an earth to the frame isnt it?
Id happilly try all three, but i dont want to burn a new dash unit out fooking about so im collecting opinions as to which to try.
next will be the temp.......... Shocked im guessing thats a lead from the engine as its air cooled? I may just leave that option off.....
PostPosted: 12:47 - 10 Feb 2016    Post subject: Re: Wiring a tachometer (in dash unit) what does it connect Reply with quote
Alot of air cooled bikes don't have temperature sensors.
Pete.
PostPosted: 14:01 - 10 Feb 2016    Post subject: Re: Wiring a tachometer (in dash unit) what does it connect Reply with quote
Yep, can work. You're making a coil and it will (might) pick up the pulse of the spark as it passes down the lead. Safe to try at least just keep the bare end away from the plug lead ends. The more turns you get round the plug lead, and the tighter you make them the better.
Again, might work won't do any harm to try. The 12v input will theoretically never change but in reality when the coil is re-energised after the spark fires there will be a drop.
3. bizzarely, id have thought, attatch it to the negative of the coil. I must surely be missundertanding no 3 as thats just an earth to the frame isnt it?
Nope, it depends on the ignition system where it goes but it'll never be direct to earth unless it's a lawnmower. This is probably the most likely place you'll find a tach signal actually. No harm to be done by trying.
As Chris said, air-cooled don't usually have temp sensors. You could fit in the fins with high-temperature epoxy or something but you'd have to cobble up a driving circuit and even then would it tell you anything meaningful?
a.k.a 'Geri'
oberonspacefr...
PostPosted: 15:22 - 10 Feb 2016    Post subject: Reply with quote
nope, your right. its got a wire for it, so i was going to try and wire it all without really thinking. i wouldnt know if 180 degrees was good or bad-as you say no need really.
somtimes you have to pause for though dont you..... Laughing
ill try the ground first, as that seems safest.
The last post was made 10 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 43.58 Kb
