Ignition is sticking, steering lock stuck on
MedicalBiker
PostPosted: 15:08 - 10 Feb 2016    Post subject: Ignition is sticking, steering lock stuck on Reply with quote
I've found the issue is worse when it's cold/wet but sometimes my key won't turn in the ignition, and I'm stuck for 5 mins trying to get the steering lock off.
Guy at the garage suggested some WD40 down the slot, other things I've read have included heating the key. Does anybody have any other idea? I've currently got the WD40 sitting in the lock.
The key does turn eventually with a lot of removal and reinsertion and jiggling of the handle bars but it's a major PITA
PostPosted: 15:13 - 10 Feb 2016    Post subject: Reply with quote
Is it a Suzuki or Yamaha? Both of those for me have needed a serious wiggle wiggle.
Get some graphite and rub over the key.
MedicalBiker
PostPosted: 15:52 - 10 Feb 2016    Post subject: Reply with quote
It's the 3rd option, a Honda.
Is that to dislodge anything that could be in the barrel? Any ideas on where I could purchase some?
PostPosted: 15:53 - 10 Feb 2016    Post subject: Re: Ignition is sticking, steering lock stuck on Reply with quote
Oh dear.
WD-40 is a solvent and some very light oil. It does disperse water, it does dissolve grease and crud, but any residual lubrication is minimal.
For locks I go graphite powder (eBay, I have some left over from using it to "lube" the belt drive on my 305), or in extremis, if it seems like it's just not engaging with the pins, I've had luck with packing grease in.
What sort of grease is a whole other bun-fight.
PostPosted: 15:56 - 10 Feb 2016    Post subject: Reply with quote
This the one that blew over? Was the steering lock on when it blew over?
Could have bent the lock pin or damaged the hole in the yoke the pin goes into. In which case it might need taking apart and fixing or a new lock.
Don't put graphite in ignition locks. I used to too but it can get into the switchgear and is conductive.
Use silicone spray to lubricate an ignition lock.
MedicalBiker
PostPosted: 16:10 - 10 Feb 2016    Post subject: Reply with quote
It's the same bike yes, although this was a problem before the fall too. Just thought seeing as I'm about to get a tool set and torque wrench I may as well go about doing all the DIY I can whilst I'm off.
I have some silicone lube that came with my Arai helmet, is that as effective as silicone spray?
Bought the new indicator today so will try and fit that tomorrow once i've picked up https://www.halfords.com/workshop-tools/tools/hand-tools/halfords-professional-torque-wrench-8-60nm
and
https://www.halfords.com/workshop-tools/tools/socket-sets/halfords-advanced-professional-170-piece-socket-ratchet-spanner-set
PostPosted: 16:16 - 10 Feb 2016    Post subject: Re: Ignition is sticking, steering lock stuck on Reply with quote
Or do what I do and scribble over it with a pencil Laughing
mudcow007
PostPosted: 16:32 - 10 Feb 2016    Post subject: Reply with quote
stanley knife (other knives are available) an scrape the life outta a pencil
That will give you loadsa graphite dust?
DrSnoosnoo
PostPosted: 16:47 - 10 Feb 2016    Post subject: Reply with quote
If you're lucky, you'll make some mega expensive graphene too, so don't waste it!
Wonko The Sane
PostPosted: 21:55 - 10 Feb 2016    Post subject: Reply with quote
My kawasaki can be a bit temperamental with the steering lock,
not pushing the key in while doing it is the trick for me as it's possible to push it too far into the lock.
GT85 helps
MedicalBiker
PostPosted: 22:12 - 10 Feb 2016    Post subject: Reply with quote
GT85 helps
I've found that with mine too, but then to disengage the steering lock I have to push and twist so...it's a bit of a murky ground I think. Just leave's me up s**t creek without a paddle
PostPosted: 08:36 - 11 Feb 2016    Post subject: Reply with quote
So we're clear, a steering lock will hold up a bike thief for perhaps four seconds, or if they're being super careful as many as 13.
Anybody who wants your bike isn't going to be stopped by a steering lock.
PostPosted: 08:39 - 11 Feb 2016    Post subject: Reply with quote
Indeed. Exactly why I've not bothered replacing my ignition.
MedicalBiker
PostPosted: 11:55 - 11 Feb 2016    Post subject: Reply with quote
So the two of you don't use the steering lock at all? Just turn to off and then turn the bars?
I thought about it, also the fact that a broken steering lock will bend and bugger the bars. Haven't brought myself to leave the lock off yet though.
Just as a side bar, I'm struggling to find places on the bike to run the chain through to lock it up at night, I'm doing that pathetic chain through the back wheel. Where on earth on a cbf can I lock the wheel to the frame? The gap under the top box rack is too small
Currently riding: 2010 Honda CBF 125
PostPosted: 12:26 - 11 Feb 2016    Post subject: Reply with quote
I only use the steering lock as an alternative to using literally nothing else. When popping into a shop for a few minutes, for example.
Can you get your chain through the rear footpeg hangar? If not, can you get your lock around both that and the chain? I use a huge shackle lock on the Beemer and can actually get it round a chassis tube with enough room to slip a 13mm 16mm chain loop on it as well.
PostPosted: 12:33 - 11 Feb 2016    Post subject: Reply with quote
I do not use it. in fact, the mechanism no longer exists on my bike.
CaNsA
PostPosted: 13:13 - 11 Feb 2016    Post subject: Reply with quote
Silicone spray.
Flood the ignition with it.
Enjoy a simple life.
stirlinggaz
PostPosted: 13:36 - 11 Feb 2016    Post subject: Reply with quote
hi,
i use the steeing lock all the time, not because i think it would stop any potential thief, but because its 1 of the 1st questions asked by insurance co.'s when a bike is stolen.... i'd hate to think what their response would be if the answer to that question waS "nope, steering lock not used cos cba'd"....
on a side note, that torque wrench looks nice (i like tools..ooh er..) & i'd be interested in any reviews.
cheers,
GAZ
PostPosted: 14:07 - 11 Feb 2016    Post subject: Reply with quote
stirlinggaz wrote:
hi,
cheers,
GAZ
How would they know, if they recover it you want it back, if its not recovered then they broke the steering lock m8.
PostPosted: 14:13 - 11 Feb 2016    Post subject: Reply with quote
Can't think why it would be, if it's not (channels arry) a condition precedent to insurance.
And "absolutely, my dear sir, I am positive that it was," would always be my answer.
The bike needs to be found before they can argue the toss, at which point they've got no need to argue the toss.
stirlinggaz
PostPosted: 14:43 - 11 Feb 2016    Post subject: Reply with quote
maybe im just too honest....(or a wummin) & as much as i hate the insurace cartel, dishonesty is 1 of the reasons they claim premiums keep increasing, so why contribute to this?
& its DEFINITELY (well certainly was last time i looked) a clause in my carole nash fc policy where it states the steering lock MUST be engaged (in the event of a theft claim) or a further excess of £500 will apply on top of any voluntary excess (£250) AND compulsory excess (£100).
that would be 850 quid lost cos i couldnt cba'd to engage the steering lock & decided to be honest.
f*ck that!
cheers,
GAZ
PostPosted: 14:50 - 11 Feb 2016    Post subject: Reply with quote
Problem with insurance is they rinse the max out of you and offer a basic bit of paper back that you may or may not claim on each year, its one massive bucket of cash.
I'd rather get the most out of them for the smallest amount, all insurance companies want is money.
CBFcarl
PostPosted: 15:25 - 11 Feb 2016    Post subject: Reply with quote
MedicalBiker wrote:
....on a cbf
I have the same issue with my CBF. I had always put it down to the fact that I leave the bike outside at night, or thought that some scrote had tried to steal the bike and damaged it.
I have used WD40 in the past, but someone recommended dry lube (normally used for the chain on my mountain bike). Haven't had an issue since.
thx1138 wrote: Well if you had a car, I'd bet it would smell like urine had had drunken sex with vomit and made a poo baby.
Polarbear wrote: They are all old now. Probably had more abuse that a Rotherham schoolgirl.
Hellkat wrote: I want to know if Nigella smells of garlic, or just minge.
PostPosted: 16:00 - 11 Feb 2016    Post subject: Reply with quote
Had (including ones that were stolen more than once) 8 bikes stolen.
Got 6 of the bikes back. 5 had broken ignition locks.
I leave the keys in them in my garage so if it's stolen and turns up again, I don't have to replace switchgear/handlebars/ignition locks.
Claimed for one of them. Wish I hadn't. Felt like being robbed a second time.
The last post was made 10 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 124.23 Kb
