Battery Question
Parson
PostPosted: 15:13 - 10 Feb 2016    Post subject: Battery Question Reply with quote
I put a new battery in my bike last year. Come November the bike was put away in my parents garage for the winter, meant to get a trickle charger, just never got round to it.
Due to the nice weather, and a day off work, I went through to get it out for a spin. Battery is dead, won't even light up the dash lights.
I was going to put it on charge (normal charger, not trickle) but don't know when I would get back through to check it, so didn't bother.
Have I killed the battery, or should it take a charge again?
Trickle charger just ordered from Amazon.
Then gsx650F - Now VFR800F
PostPosted: 15:46 - 10 Feb 2016    Post subject: Reply with quote
Only one way to find out and that's to charge it and try it.
If it's totally flat, a modern charger may not notice it's connected to anything and just sit there. You sometimes have to connect the charger up then "jump" start the charger using a fully charged battery or 12v power source to get it to start charging.
Received wisdom says if you have to do this, it's dead and needs to be replaced. I have found this not to be the case.
Parson
PostPosted: 16:53 - 10 Feb 2016    Post subject: Reply with quote
I intend to give it a charge with a booster charger, then if it starts, I'll put a trickle charger on it.
I guess if it comes to it, I'll need to just chalk it up to a lesson learned, and buy another battery.
stirlinggaz
PostPosted: 14:03 - 11 Feb 2016    Post subject: Reply with quote
Hi,
forget cheap trickle chargers & "normal" chargers & definitely AVOID chargers intended for cars.
the car charger i have, even states in the instruction manual to NOT USE on batteries less than 20ah & every bike i have owned/worked on has been between 4amps -16amps.
instead, buy a "decent" charger, intended for motorcycle batteries or batteries as small as 4amp.
specifically, buy a charger that claims to "recover deeply discharged batteries" (the model i have claims to recover from as low as 4v whereas a standard charger wont recover anything less than 10v ime) & also recovers "sulphated batteries".
i have recovered many "dead" batteries, that i chucked in the corner of the garage, years ago.
all it took was a top up with distilled water (or is it de-ionised water? i can never remember, but was very cheap for the 4L i bought a couple of years ago & i havnt used half of it) and overnight on the fancy charger.
they now show over 12.8v & hold a charge.
I used to buy cheap batteries & replace them every year or 2, (sometimes more frequently if it was left outside over winter)
but i havnt bought a new battery since receiving the charger as a xmas present a few years ago.
cheers,
GAZ.
The last post was made 10 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 41.34 Kb
