| oberonspacefr... |
 oberonspacefr... Nova Slayer
 Posted: 16:37 - 11 Feb 2016 Post subject: Last attempt at wiring or it goes to the shop. With video. |
Megelli 2009 125r
Ive rewired this bike, and now its worse.
no surprise really, electrics is deffo not my strong point.
Tried to do everything properly, bought all the correct components, but at the end of the day, I just dont understand how electrics function well enough to use a logical repair method.
the bike was running, but it was so butchered, i couldnt safely leave it so taped up and dangly.
I took all the tape off, and made a map of where everything went.
https://img.photobucket.com/albums/v260/oberonspacefruit/DSC_0256_zpshjqimouv.jpg
I then re taped it, put new crimped connecters and fitted them in mostly new blocks.
I had a dry run on the table, and got all the lights and indicators working, as they were not attatched when i got the bike.
I put the loom back on the bike, and it immediately blew the fuse.
after a bit of cursing and head scratching, i worked out that the live feed form the battery went to to the kill swith on the right hand switchgear.
i unplugged the righthand switchgear, and it stips blowing the main fuse.
SO.......somthing from that point is blowing the fuse.
I dismantled the switchgear and the black and white wire that connects to the kill switch, has a green wire on the other side of the switch.
i disconnected the green wire from the main block, plugged the block back in, and it didnt blow the fuse.
so, to sumarise, turning the ign on, sends power via a black and white lead to the kill switch. at this point, none of the other spades inthe R/H switchgear are live. it hits the switch, and turns the green wire live. this then blows the fuse, if the green wire is in place in the multiblock.
if you turn the kill switch to run, it cancels the power to the green wire.
if you set it to kill, the green wire from the other side of the switch is made live.
from my diagram this green wire connects to a big lump of greens, which in turn got to pretty much everything.
nothing works, without this green wire out of its block, and i cant tell if anything works with it back in its block as it immediately burns the fuse when its in place.
I dont know what to do next other than take it to an electrician.
it must be somthing ive done, as it was running before, but I tried hard to keep to the diagram that i made when dismantling the loom.
The easy answer would be to buy a new loom, but they are not available.
| oberonspacefr... |
| Vincent 2 |
 Vincent 2 Nova Slayer
| oberonspacefr... |
 Posted: 17:39 - 11 Feb 2016 Post subject: |
| Vincent 2 |
| oberonspacefr... |
| Vincent |
 Vincent Banned
| oberonspacefr... |
| Vincent |
 Vincent Banned
| oberonspacefr... |
 Posted: 18:30 - 11 Feb 2016 Post subject: |
unfortunately that megeli parts catalogue is now defunct. if you click on any link it goes 404 on you. |
| Vincent |
 Vincent Banned
| oberonspacefr... |
| oberonspacefr... |
 Posted: 18:43 - 11 Feb 2016 Post subject: Re: re-wire |
| spagiratwink wrote: | Hi again matey , from what I can see , the green wire which is the earth is live , and its lighting up the frame . Did you put a new kill switch on and wire it up , I know I`m sounding simple but maybe the wiring problem is at the kill switch itself or a connection problem with the live black and white wire to the kill switch |
I didnt touch the wiring inside the switch.
i did, however, replace the entire right hand switchgear as the old one was missing the light switch.
so, the green earth wire is live,(you can see that in the vid) but how? well, more importantly, how can it be made not to.......
ive looked at several wiring diagrams, but I cant decifer anything, other than it seems green is acommon colour for earth wire. |
| oberonspacefr... |
| Vincent |
 Vincent Banned
 Posted: 18:48 - 11 Feb 2016 Post subject: |
Buggers... They should still have some support somewhere. Trying to patch up a bodged loom can be like welding something rusty, you fix one bit ...then it fails elsewhere.
I'd be isolating certain components first, ie, anything not required for running, inc the kill switch. Don't the kill switches usually work by grounding power that goes to the ignition? ____________________ Space Is Deep |
| oberonspacefr... |
| oberonspacefr... |
| oberonspacefr... |
| Vincent |
 Vincent Banned
 Posted: 18:58 - 11 Feb 2016 Post subject: |
Megelli have a new web site for the UK, did you see this and/or try some of the contact numbers?
https://www.megelli.com/#!distribution/c7hs
These bikes seem to be amongst those being ridden by rebels/terrorists in Syria.
They certainly get a bit of a slating online  ____________________ Space Is Deep |
| oberonspacefr... |
| Vincent |
 Vincent Banned
 Posted: 19:15 - 11 Feb 2016 Post subject: |
Aye...they're nice looking bikes....."All that glitters......." though
I've been fixing my own bikes for centuries and still hate doing anything electrical, it doesn't get much better.
The live wire...is it specifically for the kill switch part of the R'H switchgear or could it supply the lights? ____________________ Space Is Deep |
| Vincent 2 |
 Posted: 21:38 - 11 Feb 2016 Post subject: re-wire |
Hi found this , although its not exactly the same , but the Chinese theme is , may help you with the structure of the loom although colours might be slightly different , as you can see with this one there is black/white wire and a white/black wire . Hope it helps
https://www.dropbox.com/s/agmh3use90qlbkq/125cc_Wiregram_AC%20%282%29.pdf?dl=0 |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 23:05 - 11 Feb 2016 Post subject: |
At this point, I'd be tempted to break it into bits and sell it part by part and buy something a bit more popular and working.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Vincent 2 |
 Posted: 04:36 - 12 Feb 2016 Post subject: re-wire |
| oberonspacefr... |
The last post was made 10 years, 40 days ago. Instead of replying here, would creating a new thread be more useful? |
